I hate rust..
Went down to my local kwik fit, to get the tracking done on the car. They jack it up, have a look at it, and call me over. First time I've looked underneath the car as well. They then point out that they cant do my tracking, because its too rusty. I pop down to HiQ down the road, and they said the same thing, and offered to fix the problem & tracking for £100 odd. By the looks of things, I think I need a new subframe anyways, because the four corners are really rusty. I know the car spent the majority of its time in aberdeen, as thats where the previous owner lived. The suspension is a tad rusty as well, but that aint gonna bother me, will be dropping it as soon as I can afford 16", otherwise the belly of the car is in perfectly good condition. Its just the front two corners / wheel areas that are rusty. :?
  • Replies 21
  • Views 2.8k
meh, you should see the back axel on some mk2/mk3's. I'd be surprised if its rotten and carn't be fixed, should just be surface rust which will sand off and you can paint it.
meh, mines had loads of rust work done, its a typical 6n.
the more work you get done to your car, the more you will grow to love it.
dont get the tracking done till you lower it though, pointless.
just like getting 16's
14's, maybe 15's, then your talking.
spilz
as if we both put "meh,"
at the same time
weiiiiird
I'll have a see at what they're replacing. I doubt its a full subframe lol. I might just save up for a full subframe, and have it coated to prevent rust :) Hammerite all the way!!
at the same time
weiiiiird
:lol::smoke:
I'll have a see at what they're replacing. I doubt its a full subframe lol. I might just save up for a full subframe, and have it coated to prevent rust Hammerite all the way!!
I hope for your sake their not replacing the whole thing! Bet they are killer exspensive.
just slam it on coilovers, youl soon scrape your subframe till its polished
Dont reckon 16" work on the 6n? I just wanna get a flush arch look, when I lower the car. I got told 16" are good for this =/
no mate, they look too big for the car i think, 15's and lower, or 14's and even lower.
14's would look better
I think 16s look fine on a 6N. 15s are the best size imo. 14s only work if you have the correct stance, if you don't, they just look rubbish.
what this man said!
same for 6n2 i had 14's and it was slammed it looked wrong now on 16's and they look shit hot but are causing me problems cos of adaptors etc.
so am gonna settle for some 15's
Who was it that said 16"s dont work on a 6N? Well heres proof that they do.........
spose that just sums up the fact that it depends what you like lol.
but i thought dilz's car looked good on the 13" banded steels.
Only cause its really low. If it was higher it would look gay.
yer but you could say that about any size lol.
if you put 16's on an didnt lower it, it would look like a rollerskate. 8-)
I'm just sayin that he got away with 13's on his, so 14" and 15" work a bit easier.and you would hardly be able to get a good lowerage without scrubbage on 16's, unless you had 195-5-16 tyres or somethin :-p
i think 14" 15" and coilovers will always be the way forward for 6ns, until jap style comes back in, when the chavs take over.
doesnt matter how low u go on 13's 14 there is still a big arch gap from left to right and this is why i couldnt get mine to look right on 14's maybe wider rims at the front might have helped
(opening door noise)
(footsteps)
(closing door noise)
(silence)
i cant be bothered to argue lol :-p
Nothing wrong with 16's, but llimits you to how low you want to be, dont listen to people on here saying 13's or 14's look gay unless you're really low, they're gay.. your car so do what you want with it :thumbsup:
I aint really looking to go too low, prolly 60mm or something is more than enough, as I shouldnt get alot of scrubbing, and all I'd need to do is go that tad bit slower over speed bumps or summin :)
you'll be fine over most bumps at 60mm, n u should be able to pull that height off if your having 16's, what width was you thinking though and are you having a stretched tyre or just a suitable size for the rim? this will compensate rubbing and how low you can go etc
15s ftw they are the besr compromise of looks and practicality (kind of practicality, even thogu i can't drive to my gfs new house withough the subframe scraping the floorr) but just imagine what it would be like any lower, its scary enough as it is tbh 16s can work though but it is all about stance
Tbh, I haven't got the slighest clue as to which tyre I'm going to get. I'm hoping to get yokos, thats about it.
