mk2 golf turbo diesel
the mk2s up for sale, got a lupo now so no longer need it....
was my dads car before mine, nice drive with enough poke when you need it and great diesel MPG (or run it on vege oil ;) )
went through the last MOT just needing a rear wheel bearing and a sidelight bulb. the wheel bearing that wasnt replaced for the MOT now needs changing though.
my dad put new rear brakes on it a few months before i bought it (drums/pads/cylinders)
the starter motor sticks sometimes (after its started, not before) but it always starts first turn of the key.
there is a little oil in the water, its been like this for a while, I'm guessing its the oil cooler, as it always starts spot on and never gets above temp.
9 months MOT.
tax till january.
140k (will confirm)
its on coilovers with new topmounts
all red rears
90 spec colour coded booth plinth
90 spec door trims
lay flat wiper
American Rabbit Diesel badge
£800. doesnt come with the split rims pictured, comes on standard steelies, or i can probably sort out some teardrops.
located Stroud, Gloucestershire, 5 mins from J13 M5
  • Views 733
Hi nice car. Is it an SB engine code with an intercooler? And what interior does it have?
would have to check about the engine code, but yes, it is intercooled.
it has a black/grey inteiror, thats in good condition.
cheers.
Edited by G40_Jos
All intercooled ones are SB engine code - non-intercooled are RA engine code.
i've got one of these too! very good MPG 50+ even if you toast it!
heres the interior, it looks a bit lighter in the pics than they actually are...
PMs sent.
very smart!
if only you were up for swaps...
i could only really take wheels in part ex I'm affriad mate, not got the room on the drive at the moment!
and a bump!
SOLD>
