lots of parts including handles
i do apologise for the scatter but I've had to copy this from loads of forums :lol: and this isnt my whole whack as i have some bits at home i have forgotten :)
if yu want any info dont hesitate to get in touch though ;)
handles:
handles from a 3dr black 6n2 (but i dont know the paint code). both sides have holes for locks and I'm sure they will fit a 5dr too :)
they are in fairly good condition but it looks like 1 has been touched up possibly as it has a couple small runs in the paint but nothing mojor...
there are no scrapes or chunks out of the handle but on the (i assume drivers side) ther is a couple tiny bumps round the key hole but they really are tiny and again nothing major.
they come with both gaskets but as yu can see from the 2nd pic only part of the locks are still in place so these will have to be removed and your own put in place. please note yu will be required to remove the barrels that are in place as i think yu need the key to do it so it will most likely need to be removed by drilling and i accept no resposibility :)
not sure if these fit 6n polo's as well so may be worth checkin :)
these are perfect if yu have crappy bare plastic handles and are also easier to color code than the normal plastic ones as yu only have to remove the paint and the primer is still in place :)
looking for £12 posted :)
got a pair of handles used on passats/golfs/octavias/polo's/most newish vw's and skodas and some seats.
they are ice blue i think? a sort of powder blue color. both have a couple little marks on them but nothing drastic. I'm not sure what car this was a standard color on (they were from a passat originally) but they can be sanded down and painted another color alot easier than black plastic handles as yu dont need plastic adhesive or as much primer :)
come as main handle and end cap (but no metal inserts as yu will use your own). as yu can see from the pic i only have painted one end cap (key hole side) but i am putting in a non painted black cap and yu can swap the painted hole cap for another non painted blank :) if that makes sense :lol:
easy to fit if your car has handles on already :lmao:
mk3 polo/mk2 golf/etc/etc exterior door handle. plastic type in good condition. however as yu can see from the pic it has no lock and the moving mechanism from the back of it is gone now. these were all used in the apadtation of my porsche handles. this is perfect for replacing snapped handle - £3
brand new door lock set with 2 keys for mk2 golf/mk3 polo/etc/etc. 2 locks complete with tumblers. never fitted as they were removed from aftermarket mk3 polo door handle set and i fitted original locks - £6 for locks and keys
random interior parts:
2 pairs of silver door pins. one pair in sealed box (shown in pic) and other pair taken out but never fited - £2.50 pair
one pair of chrome/silver door latches from a mk4 golf with chrome/silver bolts. will polish and clean if wanted - £4 pair (bolts not shown but i have them)
full set of mk3 golf/mk4 polo heater knobs in black in excelent condition - £2 for the 3
mk4 polo backlit needles (white versions). full set - £3 for full set of 4.
fluro orange needles from color concept mk3 golf instrument cluster. only have 2 large (speedo) and one small (fuel/temp) all in excelent condition - 50p each (these arent shown but they are about somewhere)
various OEM door pins, all excelent condition (2 mk4 "style" ones shown) - 50p each
cosmic racing gear boaby. pretty good condition but missing sticker from top. has grub screw and one plastic spacer. half blue "leather-ish" top. never fitted - £5
mk3 polo steering wheel insert from GT type steering wheel (plastic part that should be silver). painted red with a slight sparkle - £1 (not shown but pretty sure its lying about)
2x mk3 polo steering wheel insert from GT type wheel. these ones are OEM silver unlike one above. one slightly marked at edge as yu can see in pic) - £1.50
mk3 polo steering wheel centre (from GT type steering wheel). good condition but VW badge (badly) sprayed silver - £3 (not shown but sure its somewhere)
mk4 golf/polo OEM leathertte gear gaitor with elestic bottom. small hole in it but can be put to the back so it isnt on show - £3
mk4 golf/polo OEM gear boaby and leatherette gaitor with elastic bottom. slightly worn and faded gaitor with quite a considerable sized hole. also missing gear configuration from atop boaby but boaby otherwise good - £7
mk4 golf OEM interior door handle set. all polished chrome - £12 set of 4
random exterior parts:
mk3 golf front indicator. clear type good condition but was sealed with silicone as was letting water in. now water tight - £3
underbonnet soundproofing clips form mk3 golf. may fit others. all in excelent condition - 50p each (not shown but somewhere)
mk3 polo petrol caps. black one still has info stickers on the back. rusty black one is £4, "rat" style one is £4 (this is just surface rust and is red on the reverse)
mk3 golf rear light bulb holder. unknown working condition but looks fresh. £3
Chrome VW front badge. very good condition with minor dents from stones. bought by mistake. part no. 3BO 853 601/3BO 853 601A. apparently for passat but unknown. best check first ;) all clips intact and good to go! perfect for painting etc :D - £8
mk1/2 golf/mk1/2/3polo/etc/etc early handle inserts. from left to right.
first 2 are plastic and painted satin silver (scraped but will be re-painted if required) - 50p each
next is a aftermarket black plastic. doesnt fit to good - 40p
next one is metal but powdercoated black - £2.50
next 4 are metal and will be polished up using autoglym - £2.50 each
next 2 are metal and have been subjected to my crazy paint schemes. RARE!!!!! - £2 each
was going to keep 2 for my next car (unknown but it will be an older dub) but my porsche handles overule them!)
the pictures below contain everything in the above list! please ask for more pics and info if needed ;)
PS. CLICK ON PICTURES TO BRING UP BIGGER VERSIONS FOR A BETTER LOOK :D
Edited by koosh
  • Replies 16
  • Views 572
How much would delivery cost for
And is the paint orange or red i cant quite make it out.
sorry dude they have been sold :) so have all the other chrome handles :)
i may have more in soon though so iwill give yu a shout if i get any more ;)
the interior chrome handles.... what are they out of or are they sold, I'm not sure what you class as chrome handles :lol:
Any mk5 door pins?
Polomon i was after the external mk3 handle inserts.
thanks mate, it was the last comment from koosh that had me wondering what he classed as handles, I'm guessing external now so its sweet thanks dude :thumbsup:
the 6 exterior chrome handles and the 2 silver ones are sold. the interior ones i still have and they are out a mk4 golf so I'm pretty sure they dont fit any polo...
i dont have any mk5 pins. the only ones i have are screw in/out and i think mk5's are stuck in?
everything apart from the above post is still for sale :)
also a pair of de-locked handles (see my other post) :)
Hi Koosh,
I'll take the set of Mk 4 door pins if they are still up for grabs pls
Let me know (and ignore my earlier question) ;)
haha i was just about to reply to yu on the other thread :D I'm pretty sure i still have em but i'll double check tonigt and let yu know ;)
will PM yu too :)
Hi are the silver door pins still available?
Would they fit a 6n2?
Luke
sorry to people waiting on pics etc. not been home since yesterday morning yet :)
and the silver door pins are no good for a 6n2 sorry :)
all still availible :)
give me a offer if yu feel orices are unreasonable :lol:
everything still good to go :)
still got all the above stuff :)
let me know if yu want any :p
everything good to go still!
