Vw polo open air
hi could anyone tell me how to remove an open air model sun roof its of a 3 door 1996 model. i need a new part for one any one got any suggestions, ?
thanks rich
  • Replies 10
  • Views 2.7k
I would suggest haynes manual.. that would give you pictures also :)
i removed mine mate when it went into my mates body shop!
headling removal.
firstly remove all the grab handles and both sun visors
Unclip and remove the interior light
open the sun roof and pull off the seal that is round the edge where the headlining meets the vinyl its split at the rear in the middle (opening it just makes it easier to remove not necessary)
there is a strip of plastic running along the back of the headlining where the boot is hinged pull this off ( all trim is clipped in so don't be afraid to give it a tug)
u should be able to maneuver the headlining out if you unclip the tops of the a b and c pillars then slide it out the boot
once you have that out you have access to the full sunroof
sunroof removal.
their is a metal frame running all round the vinyl roof, and it has a large amount of torx screws in it, undo all these and the metal frame will drop down. remove this from the car and then the vinyl section should pus up and out of the car. i would suggest pushing it from each corner as it will unlikely have been touched or removed since it was built and it can be a snug fit.
hope that helps any more info needed pm me matey!
Christian
Edited by chrispy
jesus chris, I'm gna have to start calling you mr haynes :-o
Edited by POLOMON
He's better than, Haynes manual doen't cover this.
:lol: shaweeeeet! our own openair advice guru :lol:
Edited by POLOMON
  • 1 year later...
Sweet Guide. :D
Cheers for that Chispy!! exactly what i needed.
and you don't by any chance no the part number of a new roof? or where i could buy one? mine's a bit worn!
cheers
Hey Chipsy u wouldnt happen to know what size torx scredrive i would need would u
Its about a 6mm, whatever that is in torx language!
Pretty easy to do but theres literally 40 torx heads to remove. Takes agesss! But then u literally drop the metal frame down and the top lifts out!
Jobs a gooden!
