rolling arches diy help
right borrowing neccessary tools to hammer my arch lip in tomorrow. dolly etc
will i need to seal them after? and advice tips on doing it this way would be great, huw
  • Replies 8
  • Views 2k
ok if you are using a hammer and a dolly, you need to start at one end and very slowly knock it in say 15% with the dolly on the outside. its easyer with the wheel off and jacked up. anyway the idea is you work you way round just doing a little bit then start again knocking it in to 30% . it should take about 4-5 times round to do it properly. the idea behind this is you dont want to streach the metal as it will crack on the edges. by doing it slowly you are easing the metal in to place, if you do it all in one go it will streach!
something else yo can do is run a length of wire round the lip so when you flatten it it wont have a sharp edge.
the problem with doing it with a hammer and dolly is you will crack the paint, you may even need a very thin skin of bog as it will have very small dents in it.
if you can get hold of one of thoses proper arch rolling tools you can heat the arch up first and it doesnt crack it.
oh and one last thing the rear arches are double skinned and they do require a beating to get them to move anywhere( when i did a full flair on my jetta arches the rear ones took me 3 hours each to beat out).
anyway good luck i hope this helps you a bit just take your time and think about what your doing and you will be fine :-D
thanks for the reply! i can borrow hammer off a mate whose a panel beater, and i cant afford a proper rolling machine unfortunately.
i was worried the rears would be double skinned, if a friend heats it up while i do it it might work better.
thanks for the advice definatelly helped!
huw
you i might make it a bit easyer but like i said i think the paint will still crack beacause of the impact shock but you never know
no problems anytime
I have a arch roller at my tamworth and hagley road WHEELMANINA stores £25 - £40 per side depending on work involved. Although it is heated and rolled the Paint can still crack due to cars age and previous works! 01827 282020 (me - shop manager Tamworth) 0121 429 2951 (lee - shop manager hagley rd)
If its on your mk1 I'd say try and find someone who knows what tehre doing. Last thing you want to do is ruin the arches on a mint mk1!!
their was an arch rolling tool for sale not so long back on this forum but it was £160 tis why i dint bye it. once you have done paint the inside what you have rolled back with some underseel renound for rusting like hell
you these tools are the dogs dangllys aslong as you know how to use them, as with all bodywork take your time and think and think again before you go bounding in. i would have bought that pal there are some people on these forums making a mint from hiring them out to people.
If people let me know i can borrow my arche roller from work and do them at home its well easy to just roll em! Flairing takes abit of nack though. i rolled my bosse's ferrari f430 arches the other week no probs! I'm bringing it back to do my 6n the weekend.
