Glove box lock/handle broken
Hi people, as above ma mate some how managed to break the handle apart with the lock while opening it. How can i fix or replace this? do i have to replace the whole glove box or just the lock. as the lock/handle hasn't got an screws on it to take it off? I'm stuck?! can anyone help?
  • Views 5.3k
you best going to vw and asking what they can sort out
dont see why they carnt just get a handle
you can change the handle in the glove box behind the handle there is 2 small holes get 2 nails and push themin there then the handle and lock will come out with a bitof a pull then go to vw they will order you a new handle and you will have to fit your lock into the new 1 so tha it keeps the key the same its only a clip on the back all this will only take bout 1 mins to do once you got the new handle as i had to do it before on my gti
cheers guys, got the handle from vw £12.10. clips off when you put the pins behind it. the barrel just pops in with a click. very easy, i didn't have a clue at first!
This happened to mine the other day - just opened the glove box and the handle went all screwy. Has anyone done a "how to"? :lol:
ditto...same happened to me a couple of weeks ago, thought id need a new glovebox!...is there a how to about ? an idiot like me would need one lol :lol:
