Door rattle
Hi, My passenger door rattles on the outside and a bit on the inside badly to music even if it's not that loud, what could be the problem? cheers
  • Views 1.4k
If its just when the music is on ?
Get some sheets of sound proofing and stick it in the inside of your doors. Should stop the rattling and if not make it quieter.
Yeah it's just with the music on, what thinking about that, are the door panels easy to remove?
It is a easy job but i've only removed mk2 & mk3 polo door cards. Just look around the door card and there should be some screws and another 2 bigger screws in the pull handle + 1 in the window winder (if not elec). When all the screws are out it is only poppers holding the door card on. just pull one of the corners out and you should hear it pop out. just go all the way around the door card and lift up .
just look and take your time its easier than what it sounds!
Have taken it off and it appears the sound proofing has ripped it was vibrating lol all sorting now cheers
