Wet Seatbelt!
Evening chaps and chappeses, i'm having a very very annoying problem with my MK3.
Quite often when i put my seatbelt on it feels damp and sometime wet. It is the part of the belt that goes behind the rear doorcard into the rear quarter, i've tried all i can think of, and looked for any problems, but i just cannot come to a solution, so if anybody has had this problem, or knows of the solution, please let me know!
Cheers Very Very much in advance Rich :-(
  • Replies 15
  • Views 2.3k
sunroof drain holes blocked?
Nope! Tried them already! I actually have no idea!
which side does the washer pipe run through? i think it might be the drivers side. its probably just come loose
Bugger, i never thought of that where abouts does it run?
right by the offside (drivers side) rear quarter, i think you can actually see it if you take the door card off. do you use your rear wiper a lot?
Are you sure your not shutting the belt in the door with it hanging out :lol: ?
In this country it will defininately end up wet!!
I have the same problem
if it pisses down my belt ends up moist or soaking!
but theres no other standing water in the car?, doesnt smell damp or owt eithr? Mk3 sallon btw, no rear wiper or sunroof?
I have the same problem too, its after its been raining and i cant work out how its got wet?
come on folks, some one must know?
Not had this problem but have had plenty of other water leaks. You may have to remove the side trim & get in the car with a torch while an assistant hosepipes the car.
Been getting this on the passenger side only. Drivers is fine
Is that the sunroof drain holes?
check this panel inside the wheel well it goes alot, and lets water in and you would never know... as its in behind the filler and chocked with dry mud half the time
pray its not!
morelikely is the rear sunroof rubber drain pipes popped off. just take the door seal and sunroof edge trim off and put a hand inside an push it back on, then take the rear door card out and dry the area totally so its happy and dry
Edited by genesisGT
I've noticed this recently, but only this week after it was really pissing it down and only on the driver's side. I've got a factory steel sunroof (not tilt-and-slide, just slide - Haynes book assumes the mk3 got a tilt-and-slide only). I've checked the drain holes and they all seem to be working correctly though I need to borrow someone to pour some water down the rear OS drain hole while I look behind the rear card and see where the water's actually going.
Couple of other similar threads I found with no confirmed fixes:
http://www.clubpolo.co.uk/forum/index.php?showtopic=94887
http://www.clubpolo.co.uk/forum/index.php?showtopic=92940
Anyone else got wet seatbelts at the moment?
Edited by steveeeee
There could be a hole in the bodywork under the rear side window seal, seems to be a common rot spot. I guess you could stick your hand up inside the rear 1/4 and feel along the welded seam that the window seal fits over. You'll soon find a hole if it's there (i hope not though).
Had a good look around there and can't see any holes at all. Even shoved some kitchen roll up in the B pillar and poured more water down the sunroof drains, nothing. It's only happened that one time and it was really pissing it down, maybe a slightly loose seal somewhere.
