MK2 Squareback 1.3 Running Temps
New to polo ownership and only drove it for first time today. car runs just above the halfway mark if i keep the heater on, blower makes no difference. however i was driving the car slowly, about 30-60mph along lanes and then by-pass but this seeems a little hot to me. where do your cars run when driven gently? all waterpipes get hot, and has plenty of oil and collant in car so just wondering really
any advice appreciated
cheers
nathan
  • Views 1.4k
cheers
nathan
hmmm, my mk3 runs around 75 degrees i think, that's on an open road i.e. no traffic jams.
it might be worth replacing the thermostat (around 6 quid) checking the fan switch etc.
phone call to gsf after work then! cheers mate.
do you know how hard it is to get at thermostat - its an arse of a job on my mk2 golf 16v!!
I think if the engine is what i think it is then the housing is easy to get to, its fitting the housing back on thats the arse.
They usually have self tapping screws, when we did my golf i think Saf and I went through about 3 housings!
The mk2/3 thermostats are a bit of a pain in the arse, you'll have to be careful not to distort or pinch the seal when you try to put the front pipe back on. you may want to use a small mirror to make sure the bottom part of the pipe is sealing up properly, some guy who designed it thought it would be a breeze to do upside down :S
i always take the thermo housing off completely, it's only 2 bolts on a mk3 and a few hoses.
take it off, take old thermostat out and pop new one in. do bolts up evenly and obviously tight and it's done. i'm talking from a mk3 perspective and it took about 20 mins.
Iv been well informed GT's and the like should run at 90 degrees, if you change the thermostat i would change the housing as parts crack which means the thermostat doesnt work.
