*URGENT HELP* Wiring 7 pin headlights to 4 pin plugs
Hi, i have bought some angel eyes that have 7 pin adaptors, but my car only has the 4 pin connectors, how do i go about fitting them if it's possible my cars front ends in bits and i want to fit these before i put it back together which is today, cheers.
Edited by H@wK£R
  • Replies 9
  • Views 1.7k
remove the four pin plugs from your standard headlights, cut off the 7 pin plugs off the angel eyes and replace with the 4 pin ones...shimple
It's ok now i think i'm going to do that, but the thing is on the angel eyes there's 5 wires coming from the connector and on the original lights there's only 4 i think the one spare is the headlight adjuster is that right? i'm going to get a circuit tester to find out what wires what and do it that way.
eeerm if i can remember correctly theres two black (earth) wires on the angel eyes that can be joined together
Edited by Gugz
Correct!
Correct!
is that at me or gugz :? is the extra wire for the adjuster?
Correct!
nooo the angel eyes dont have a beam level adjustment mechanism, the extra wires just an extra earth
all your interested in:
YELLOW WIRE = DIPPED
WHITE WIRE = HIGH BEAM
BROWN WIRE = EARTH
sorry cant remember the colour of the sidelight wire!
tis a thin grey one i thinks
yup thats the one! Grey is sidelight.
the other 3 dont bother with, as explained earlier they control electronic headlight adjust!
