Removing Side Mirrors on 6n!!
wondering if anyone knows how to remove the mirror caps?
wanting to paint them but not sure how to get them off! :?
help is much appreciated :-D
  • Replies 10
  • Views 2.8k
Will alot easier to mask them out. Instead of breaking them, trying to get them off.
think you might be right.
in which case do you know how to get the whole mirror unit off?
inside the car on the rear of the mirror is a black cover, this pulls off and reveals 2/3 screwsinto the mirror base, undo these and pull the mirror away from the car, dissconnect the electrics (if fitted) and spray away :)
thank youu :D
ok :)
you might have to take the door card off, because i think there is screw which you can not get too.
should be able to acces them all i think from the nternal cover ? cant remeber either
we managed to remove em :)
door card had to be loosened a lil bit as screws 2 and 3 were below the door card line :)
thanks for the help though guys ;)
is there no way of removing just the caps? I'm also thinking of spraying mine but i want two sets to swap over if i dont like the result.
it dont look like its easy matey :)
i had a look and a pull and they werent really budging. i think maybe if yu get the mirror glass out there may be tabs etc but i didnt want to pull the glass and end up with 7 years of bad luck :lol:
just paint the whole whack ;)
