Taking off 'THE' Steering Column Spline Adaptor
You know, everyone with an aftermarket steering wheel and boss will have an answer.
Gimme!
  • Replies 8
  • Views 1.7k
puller :)
An aftermarket boss,is it? Could be tight.
Id get some WD in there,get a steering wheel on it,and work it side by side. Always make sure the nut is on a couple of turns,as you dont want the wheel pulling off into your face.
If its going nowhere,a lump hammer and punch-bar from behind,under the column,should work. Quarter turn the hub every few hits. If all that failed,it'd be dentistry time.
just get violent with it
it will go in the end :-D
The faithful two hammer technique.
If that fails, grinder it. But be careful you don't set fire to anything. Not that I'd know anything about that :paranoid:
there was a guide on it, remember reading it, used a puller and abit of heat iirc.
hiya dood
well i just used an angle grinder and ground 1 side until it loosened!
its not like u will ever get the nice person back on! so why save it?
+ i felt silly wen i found a boss which fitted n didnt need the butchery
KiZ
Late golf bosses fit without taking the large spline adaptor off - clearly not enough people know this!
OMP Boss VW149C, as opposed to small-spline VW145 - mine is on it's way.
Late Mk2 Golf bosses, early Mk3 Golf bosses, Mk3 Polo bosses etc... yeah, they fit. I could have told you that if you'd asked. lol.
