What are GT's like?
I currently have a Corrado 16v but being 18, insurance is a killer and although I am managing it at the minute I have just decided to go back into full time education and will need to do around 50 miles a day. The Corrado gets around 30mpg on a run. Which presents a further problem financially.
Before my Corrado I had a 1.3 NZ mk3 Polo which was great fun, so I know what Polo's are like in general but I'm looking for some info on specifically GT's as I'd still like a bit of "uumph" but with the advantage of cheaper insurance, cheaper tax and better economy.
So, what are GT's like to drive daily? Round town and on the motorway.
Can I expect 40mpg on a steady motorway run?
Reliability?
How will performance compare to the Corrado bearing in mind the Corrado weighs circa 1090kg?
I'm expecting the Corrado will be much more refined and quiet. But I need something cheap for the next year or so.
Heres a pic of the Rado.
Oppinions and advice appreciated.
Cheers.
  • Replies 33
  • Views 2.5k
get 1.
You're running that at 18? :o
I recon you'll find a standardish GT pretty good fun, although it won't handle anywhere near as well as the rado!
It will probably feel like a bag of shit compared to the Corrado, they are ok lack torque massively but they like the redline.
Should see 40mpg+++ on the motorway, i have to travel 40 miles a day to uni, thinking about a turbo diesel next year :oops:
Pretty reliable if you keep on top of them, watch out for any nasty knocks from the engine although they are usually bomb proof. Changing the oil is the main thing you might want to keep on top what with the revvynesss
I used to get 40mpg on the motorway and mine wasnt bad round town either
If you can get 30 mpg from a 16v rado then you shouldn't struggle with 40 mpg from a GT
i do 50 miles a day to the airport n back...does me well as a daily.....350 miles to 35 quid, granny shifting's the future
Cheers for the advice guys. Yeah the Rado is pretty un economical.
What should i be looking to pay for a good GT? Would be looking for one preferably with a 4 branch and full exhaust system and fairly tidy paint.
I would be looking to Chip it with the 8K limiter and perhaps a nice cam later on. How do the GT's react to being reved to over 7k? Anyone had any bearings knocking or conrods through blocks?
Cheers.
1k for a good GT...what i paid :)
4 branch is a good option, i have one of those
got rid of the chip, no point to it not having a cam...yes it revs there, but theres nowt worth having up there.....just more ware on engine components
I was driving my GT (chip, induction, PhilJ 40mm kit) 90 miles round trip on the motorway every day for a few months and it was fine. Noisy and bumpy, but fine :) Averaged around 42MPG. Now I walk to work and only fill up the GT every other month. Might even be selling it soon :(
Edited by steveeeee
Yeah Neil's right.
There is little point on revving the bollocks off the standard engine, regardless of what chip it has. Changing the cam will only move the powerband up the rev range which is pointless on an otherwise standard engine that already has a revvy nature.
If it's just a daily drive for a year or so, I'd leave it pretty much standard. A decent GT that's been properly serviced should drive very nicely indeed and have more than enough performance and economy to be fun in equal measures.
Do watch out for rust on the mk3 Polo's though. Even some of the really nice and tidy ones have rusty battery trays and rust under the arch trims. They're old and Spanish built, what else would you expect?!
I had a Shrick cam in mine and it made such a difference, the revs through the range was so smooth and aggressive, well worth it with the other mods i had - i was running 100bhp.
Cheers for the info guys. Getting oppinions from people that drive them daily is helping. Theres a silver GT near me (Colchester) with black mk3 golf steels with a silver lip. Anyone on here?
i get 35mpg out of my ABD on the motorway! thats even with an ABD box
GTs make great daily drivers. I ran one for about two and a half years. Doing roughly 40 miles a day to work and back in it. It would return 40mpg no trouble and I dno't tend to drive like a granny! They're not fast and they suffer the usual mk3 polo vague front end but they handle predictably as long as you don't go silly lowering it too much and are great fun on b roads. The engine loves to rev too, but taking it beyond 6500rpm is pointless and beyond 7000 you run the risk of damaging the engine because of valve bounce, it's more than the standard valve-train can cope with. You can convert to solid lifters etc... but it's pointless as power will have started to drop off way before 7000rpm : it's time to change gear!
Reliability wise, not much goes wrong with them and even when it does they are easy to work on and parts are generally cheap.
Worst thing is due to the size and lightweight-ness of them, they aren't great on the motorway if you drive on there a lot. That's the reason I got rid of mine, my work moved offices and my drive to work, while not really any longer is now pretty much all on the M62. So I got a passat tdi which is more of a motorway mile muncher but compared to the GT it's mind numbingly boring to drive.
mine gets 47mpg going from uni to home (but that is a 3 hour drive down a motorway taking it easy behind a truck :lol: ) but for around town driving it is so much fun. but it depends on what driving you do if you do alot of motorway driving i would get some thing else just because of the gear ratio.
Cheers guys.
I quite a bit of town driving broken up by a 30 min stint on the motorway, but normally just sit at 60mph all the way so not really a problem. I remember my old Polo being an arse on the motorway. Getting blown around everywhere and being pretty sketchy, but all par for the course i guess.
^ yeah that's why I got rid of mine just too small and light to be sure-footed on the motorway. The bit of m62 I drive on to work and back is officially the highest stretch of motorway in england (seriously!) and it gets bloody windy up there in the pennines, the polo got blown about like a crisp packet some days. The lard-arse passat just feels a lot more planted to the road.
i do about 10-15 mins on the motorway, it copes well i guess...revvy, even with a lower ratio 5th gear
fun to play with otherstuff, but exhaust can get abit OTT
Great info here peeps, now wil lsomeone bloody sell me one closeby?????????????
can have mine for 1800 :p
not a chance id pay that for a GT dude lol :p
Edited by jay135
ino, was being sarcastic
bare scene tax 8-)
i know you were :p scene tax does seem to be a problem for me at the moment with people overpricing some cars I've seen knocking about on other sites!
that black "unmolestered one" wernt badly priced...you gota grab em while there around...no fanny'in about deciding if you like the colour or not
decide what you want, how much you want to spend, colour if its important, mileage e.t.c and dont get lured in to buying a shitter just cos its close
