Help plz!!!
hellp people
Me and my friend removed the runner strips from my mk4 using auto Glym tar remover. When we where done we noticed that i had 2 stunning white streaks across the car there the runners where. i have tried t-cut but i cant remove the offending mark, can anyone recommend how to get rid of this or is it a re-spray job.
Thanx
BigAL.MK4
  • Views 1.3k
search function it, its probably a water mark. search and you will what peopel have said before, usually means respray, mop and compound or shove the strips back on.
This happened to me on my drivers door, just go over it once a week with t-cut and polish and maybe try detailing clay too. it does fade (has on mine) and I'm sure it eventually will go.
Try machine polishing it.
thanx people... i will try tge T-cut 1st and then see what happens
i had a simialr problem on mine but it was much worse
i had to have mine resparayed
give it a few goes with t cut, and then move onto a machine polisher as said
I believe "higgo" had the same problem with his, however no matter how much t-cut he used it wouldnt shift it, i think he almost took it back to bare metal before giving up!
