Central Locking Help
My central locking on my volkswagen polo 1.4 16v 1998 doesn't work.. any help please?
  • Views 1.2k
Anyone want to help me?
what exactly is wrong with it m8? any locks working at all? is there any noise when you turn the key? most probably just need a new central locking pump, can get one for £30 from a scrappys. you can check by opening the boot and turning the key in a door and listening for a noise from the pump (behind the panel where the first aid kit is) no noise = new pump.
hope that helps
hope that helps
Thanks mate.. no locks work when i turn the key. What does the pump look like?
hope that helps
probly is the pump then m8, if you open the little flap thing in the boot where the first aid kit is on the right hand side theres like poylsteyrene packing behind the rear light and its in that, its a little box with a blue tube going into it and a connector with a few wires in that. once you get it out you can get the number off the bottom end get one form a scrap yard, or maybe even someone breaking a car on here.
