removin a mk2 steertin wheel??????
hi guys anyone tell me the easiest way to remove my polo mk2 steering wheel???
cheers jay.
  • Replies 11
  • Views 4.9k
yank the cover off the center ...usualy comes off by hand
then remove the big center nut ...anticlock wise to looosen
Quick tip:
Leave the centre nut on the last couple of turns, and hit the wheel from the back to take it off the spline, then remove the nut and the wheel altogether. That way you don't smack yourself in the mouth with the steering wheel when you pull it off without the nut in place.
Quick tip:
speaking from experiance there yeti :lol:
Hell leave the nut on it or you get a fat lip for sure ;)
Quick tip:
Once or twice, yes. :-(
Or you can pretend to yark it really hard, at which point someone will want to come over and prove they are more manly than you. They'll yank it and idiot themselves in the face.
cheers for the reply guys, next problem.
it dont fit rrrrrrrrrrrrrrrrrrrr
got a wheel for a coupe s an the spline is diff size.
so wots the easiest way to sort this?
remove the spline from the steerin colum or change from back of the steering wheel?????
If they're both MK2's,then you'll have to swap the steering column's aswell. The pre-'86 columns are a different design,but they're interchangeable. The later telescopic one is better.
Not a job for a novice,though.
ok anyone got a nice wheel to fit then with a large spline?????? save all the arsin around.
no more easy ways to put the wheel on??? anyone????
does the spline adaptor not come off?
so if you have the small splines then buy an adaptor , and if you have the adaptor and want to use a small spline wheel then get a puller to take it off
the mk3 polo gt streeing well fit and mk2 golf
