twin carbs,manifold,pump and regulator
hey guys i have a pair of dellorto 40's twin carb's, a brand new inlet manifold, a facet fuel pump and a king regulator/filter for sale
i bought it all a while back for an engine conversion i was doing but I've crashed the car now so I'm selling it all of as i have no need for it now.
the carbs have been stripped and painted, and checked over to make sure everything is as it should be and it is. i bought them as a special one off motersport editions that could handle 15psi of boost not that i was going to run forced induction on them hahaha!! all the butterflys snap shut cleanly and everything is inplace apart from one of the dust covers which would cost you a few quid to replace.
the inlet manifold is brand new and has only been mocked up to the head once. all the studs and nuts are there and it have a vacum hole already present.
the fuel pump is the gold tubular facet pump, it is in all good working order. this pump is built for twin carbs in mind.
the king fuel regulator is also in good working order, it just requires a new filter in it. the metal has dulled, but could be easly polished up is you so wished.
i also have a 2.0 block and box and, 1.8 head with a kent cam in it for sale pm me if you are intresed.
the price is £375 for all of it, i will take sencable offers but no daft ones please thank you.
thanks
tosh
  • Views 399
bump
Am I right in thinking this is for the big block engines?
Edited by yeha
