Renegade's Cammed Mk3 1.6 16v Hybrid
Looking good Dan, like Higgo I'll pop up and help out when I'm off work for two and half weeks from the 18th till 3rd August
  • Replies 715
  • Views 123.5k
  • grungeisdead
    grungeisdead
    chris with a mk1 golf afh engine with an 8p box fitted a mk4 fly and mk3 clutch with mk4 starter as its slimmer, the mk4 flywheel wouldnt engage so he had to take it apart again and fit a mk3 fly! g
Consult this build and PM the guy if your having any troubles, hes done quite a similar conversion renagade!
http://www.edition38.com/forums/index.php?...c=56989&hl=
Not overly sure how useful he will be Pm'ing you back as hes a busy guy but I'm sure if you post on his thread he'd be happy to help!
^^^ Well that just puts my little shed built baby to shame doesnt it! Saying that I have seen the videos of it on youtube and its a beast!
Cheers for the link tho, good build thread!
I have no finger prints on two of my fingers after sanding that rocker cover, so as long as I only use those two fingers I can commit crimes and get off scott free!
what could you do which is illegal and only requires two fingers. . . . . . . . . .
you're going to get locked up regardless.
The ninja two finger punch of death? :lol::roll:
Bit of an update
Thought the engine looked a bit sorry for itself so gave it a lick of paint whilst dodging rain showers and trying to shake the hangover
Then got a bit carried away...
Got the starter motor bolted up
Then got the engine mount into shape
Then hit a bit of a snag, the bottom adjustable bracket on the alternator didnt line up. This was odd as it should have worked exactly how it did on the mk3 engine block
So, had a cuppa and attacked it with a trusty hack-saw
Problem solved!
so this is how it stands tonight, might actually get round to dropping it in soon!
Aint no party like an S-club party!!
Peace
Lookin clean!
Wish mine looked like that :lol:
Cant wait till this goes in now dude and you get it fired up. I plan to be there by the way lmao!
Well its going to be next weekend at the very earliest for it being in, but its gona be some time after before its running lol
good work mate, I hope that extra wide alternator belt fits though as space is pretty tight on that side in a mk3, it looks even wider than a g40 toothed belt pulley which only just fits! Might just need to grind a cut out into the arb mount bracket.
Looking good, only just read through this. The starter motor can be a nightmare. I think you might have some problems with the alt belt hitting the chassis leg...
I used a mk3 alternater pulley on the crank and a normal mk3 pulley on the alternater and it seemed tight at that but you might be okay.
Yeh, its gona be tight but I'm confident it will fit with mm to spare.
Heres a pic of pauls showing just how close it gets
Another reason I think why MikeyMK chose to shift the engine over 5mm but i wouldnt have a clue how to do that!
just about to embark on this myself.
i have a mk3 and a mk4 16v donor car.
where did you source your starter and did you have to remove the mk3 engine then attempt to fit the mk4 16v to work out the bracket sizes? i dont really want to remove my mk3 engine until i know its ready to go in as it is my daily car.
do you have any measurements/sizes that you used to make the bracket from?
editted for another question! please can you get the starter motor part number so when i go round scrappers i have a better idea what i need. cheers again!
i cant wait to get to your stage, i bet your really excited!
many thanks
Rick
Edited by humer
Ahh yes. paul aka polo13 did this conversion too (i bought his mk3 4 branch off him after he slotted the afh in) are you gonna run this on injection or carbs? Would be good to see an injected afh in a mk3 :)
Luckily a friend had one lying around, its the starter from a late mk3.
If you look back in this thread somewhere there is a dimensioned up drawing of the engine mount bracket, though i had to take about 3-5mm off the bottom of that.
I dont know how quick you work but I wouldnt have thought this conversion was something you could do and still use the car as a daily, unless you were to spend 6 months collecting every single part you will need and take a week off work to fit it all?!
Rick i'll take a look in the next few days and try and get a part no.
As good as it would be to have an injected one, ( I have Pauls un-coded ECU tucked away in my room just incase) Wiring it up is too much of a job for me, I've decided to go carbs because theres less wiring basically (that and the noise of carbs)
:thumbsup:
i wanted to get rthe engine ready to drop into the mk3 then get it wired over the weekend. i teach in a coillege so i have just started my 5 weeks holidays. currently doing an ABF into a mk1 on twin 40's.
i have carbs/manifold/r1 fuel pump and 16v engine, so i reckon all i now need is starter, mk2 polo coupe S dizzy/coil and wiring. and bracket!
a page or so back you have put around 10 pictures in the same post and these wont open for me which is confusing as all the rest did>?? i assume the diagram for the bracket is in with them.
if you can offer your experience of anything i may have missed i would be greatful.
is it possible to use the mk4 downpipe and link to the mk3 exhaust as a temp measure tilli get a four branch?
thanks again
Rick
mate what sort of an effoft is that on the rocker cover, lol i shall get that mirror finish if you let me loose on it, but amazing wrk fella, cant wait to come see it, i will defo be there wednesday
Haha, well i had to stop because my fingers started bleeding!! you are welcome to have a crack at it wednesday lol
Picking parents up frow zee airport at 12ish so recond i'll be home about half 1 if you want to aim for then?
wikid, we shall have a crack at it all day the fella, i have a special little helping tool i may have to bring round :)
Might just be able to help you there matey, after friday got two weeks off from the hellhole and got nowt planned so I'd be happy to come up and help
how you getting on with this?
more updates please! need some enthusiasm for me to do something to mine!
lol, unfortunatly nothing really apart from cleaning the bay and inside wheel arches and continuing polishing of the cam cover thingy.
I'm building this on the drive so all this rain has kinda halted play! Updates over the weekend maybe
i know what you mean about the rain, it hasnt stopped here for three days and I'm also a drive only diy'er! no garages here! so we are the hard core kinda modder then!
good luck.
yer rain sucks! aint been doing the final assembly on mine because of the weather.
Mega impressed with how good the motor has cleaned up and how you did the engine mount - il look forward to seeing this car :-)
KiZ
