Central locking problem 6N
Couple of problems with my central locking... First, the boot's just randomly stopped working so I have to unlock it manually and also, the passenger door lock has just started spinning when I turn the key in it and it comes out when I try take key out (the barrel).
Anyone experienced this and know what the problem might be? How to fix it? Driver door works fine and still locks the passenger door.
  • Views 1.2k
the little paddle inside the lock barrel has probably snapped mate, the paddle is what switches the central locking mechanism
quite a common problem, just run down to a scrappy an get a new one
remove your door handle by removing the torx screw located inside the door shut next to the door catch, once its removed just slide the handle to the side an pull it out, you'l be able to see where its broken an thats the bit you'l have to replace, should only cost a few pennies
Thanks Gugz, I had a look after posting this and you're right about the paddle. I had already planned a trip to the scrappy in the morning so you've just confirmed my thinking.
Thanks again :)
Bastard! I got a couple of the paddles from the scrapyard but they were too short (even though they came off MK4 Polos... Must have been a different year, I don't remember the registrations...) so I've hard to fork out £15 for a lock repair kit off eBay because I can't be bothered to drive back over there.
