Front bumper
Sorry if this has been put up before but I need to go out so in a rush;
How do you take the front bumper off??
I have brought 1 of "Boss" :) and been delivered (i think)
Will need to know by Monday morning.
Ben
  • Views 1.3k
buy a haynes manual
I had 1 but it got lost when I moved :(
This may not be perfect, but this is what i can remeber from the haynes manual as i aint got it with me atm lol:
First, you need to take the grille off. 4 clips at the top, one just under the badge. Unclip the top 4 first, i found it easier to get off that way.
Next, take the front indicators off. Undo the screw on top of each one, they then just slide out the front and unclip the wiring plug. Now unscrew the headlight surround (there is a screw under each front indicator. You'll see them when the indicators are out).
Now you gotta take the headlights out. Two screws on the top, one on the bottom, near the middle of the light *NB: you'll need a star key to get these off, and the bottom screw is a bit of a bugger to get at at first. To get the light out, lift the bottom up first, to remove the lower lug, then it should just slide out. Don't forget to unclip the wiring plug though.
Now, the bumper should have four bolts on the top which should be easy to spot, and one bolt underneath which is located in the middle of the bumper.
Once you get those all undone, i think the bumper should come right off. The only thing i may have missed is that the arch liners in the front wings may be screwed to the bumper as well. If so, i think it's just a case of unscrewing them and you're done.
Hopefully that will help though. Let me know how you get on as I've got a 16v bumper to go on soon :) :thumbsup:
It's in three bit's mate (Y) top lower and splitter, attach the top as said above then bottom and then splitter. (Y) In three stages and it's alot easier :) Have fun unwrapping it??
Thanks Polo 1.0 :) Will get about doing it today as I have now woke up :p
Boss......Was abit of a pain in the ass unwrapping it but a sharp knife always works :D You work at Halfords by any chance??
Oh yes ;) hahaha thought it would be a fun event for you :)
