Minilights very very strange!!
hi everyone, I've got a set of minilights that i have just taken off my mini for a refurb and i thought id try em on my polo, i no they are supposed to be a mm or so out but when i put them on my GT they were completely central, everything sat traight the wheel was central and i was really confused can anyone enlighten me??? the wheels have no pcd measurments but they are genuine minilights and they fit straight onto my mini :?
  • Replies 12
  • Views 1.7k
I think the PCD is 4x101.4 so that 1.4mm is rather hard to see.
tried putting bolts through?
yep i bolted them on fully with my regulare bolts and the shafts lined up perfectly in the hole. and as they are newly sprayed they left rings marks in the centre too. are these safe to use normal bolts???
you should really be using wobble bolts with an off-centre taper on them, alot of people dont tho.
I've actually got a set of wobble bolts to go on but it turns out the originals fit. will this be safe??
id use wobble bolts to be safe
Even that 1.4mm can put extra strain on normal bolts, even if they seem to fit fine.
they are 4inch which is 4x101.6 and you should run with wobble bolts especialy as you say you have a set
you may not notice a difference now but are you willing to take a chance on your car being written off for something you have sat in your shed that you cant be botherd to fit
2 bolts out 2 back in then do the other 2
you wont even need to get your jack out to do it
wouldnt take the risk over something like that, if a wheel was to fall off when you're going down a motorway imagine how dangerous that would be?
i doubt it would fall off, but the vibrations wheres it isnt perfectly central wouldnt be particularly comfortable
i didnt say i couldnt be bothered to put wobble bolts on the fact that my wheels aren't even on the car yet proves that, just wanted opinions but now i think i shall just stick to the wibble belts.
Edited by spanner_allan
i had mini lites in mini fitment on my caddy for months with no probs at all just make sure you have the corect spigot rings!!
