too low?
can a car be too low for an mot? mines down 100 front /85 rear
& wide wheels? bareing in mind the tread is under the arches so I'm guessing this is ok?
& one last thing! i think my wishbones/subframe is pretty battered, would this be an mot failure?
cheers for any responses, I'm shitting it bout the mot! haha
  • Replies 13
  • Views 1.6k
yea mate I'm pretty sure you can be failed for "too low"
can you get it up on the ramp? can you get into the brake tester?
sorry if others dis-agree just what I've heard in the past
Edited by low n slow
hmm good point
i managed to get my car onto the ramp & get my camber & tracking done at the place
weather that makes any difference i dont know? :s
I'd reccomend you put steels on or other wheels because you could still get turned away with your wheels on, i got turned away the second the guy saw my car, i've got some 8x14 et 20 borbets with 195/45 tyres and he said no can't risk it straight away :-(
kool you should be able to get on the other ramps i woulda thought.
and I've got some idea you can test the brakes without going into that horrible rolling road thing.... but dont hold me to that
ill have to wind my golf up wen it comes to mot
the only thing that fits underneath it is my dust cap
i would wind it up personally, i did on mine, i went to the mot place and asked them first of they would mot it that low before hand, he said its prob not gonna fit on the brake tester without sitting on the subframe, they can refuse to mot it if they cant carry out the necessary checks!
made the job easier for him, peace of mind for me he didnt go driving it in the the ground on his brake tester and the car passed!
worth doin for a 15min job of adjusting the threads on the coilivers
if you cant get on the rollers they have to take it out for a drive to test it
if can be deemed unsafe tho
yeh i wound mine up and swapped wheels for the day with my mates polo breadvan :lol: mine passed but he wouldn't have passed in its current state i dont think
Id defo wind up and put other wheels on, I've got 10 months left before my MOT lol but thats what ill be doing.
wind them up i fail due to the shocks didnt have enough movement! bring it up then go lower when you go back down :p
shit son
they can fail it cos of that!?
hmm ok raise it seems like the best idea
this wont mess up my camber & tracking will it? aslong as i put it back down to the same height?
You can easily get turned away because of your wheels, some testers don't want to risk it, with VOSA
Mines in today, cant be failed for too low but if it cant get on the rollers how can they test it? Mine was too low for that so up it went last night!!
Wheels they cant fail you on as there is no law, but stretched tires they can. If a tyre is too small for the rim and exposing the beading its seen as illegal.
That sums it up for you
I usually take mine to the garage my family have been going to for years and it passes every time. I once took it to a garage in Kingston and they were not happy. They said that because the spring had to be guided back in to the (excuse my lack of technical language), plate at the bottom of the coilover once it had been raised and then lowered back down, it was a fail as this could happen on the road. My car is lowered by around 75mm (I think).
A hot rod owner spoke to me after the test and told me to raise the car and get it retested, then lower it back down after the test to avoid the problem.
