coolent hose for Mk 2 Polo, no longer made? help!
Hi.
I am not quite sure where to put this query?
Car is a 1988 Mk2 Polo C, 1043cc HZ series engine.
Recently the Top radiator hose blew ( in the dark, late at night).
I decided that after 20 years to replace all the hoses.
I got all the hoses apart from one which the local car spares shop could not find, they were told it was unavailable from VW.
The problem hose is the one that connects the rear of the thermostat to the coolant pipe that comes from the water pump.
It is about the same diameter as the top & bottom hoses, roughly 'U' shaped, about 6" long? Could post photos if needed.
Others must have come across this problem? What else fits? Seems a shame to have to scrap the car for this!!
I am wondering if I should bind it with self amalgamating tape as added support & protection? Electrical insulation tape got me home the other night!
Also, anyone have a part number for this?
Thanks for any help
  • Views 979
Self amalgamating tape will do nothing - the hose holds steam under intense pressure.
I cant believe this pipe is not available - you're not just taking someone's word for it,are you? Whilst possibly slightly different,the same pipe from a 1.4 MK3 (mid 90s) Golf and early 90s MK2F 1.0-1.3 Polo's will fit,if clamped on with a screw-tight type clip.
I actually have one right here,so yes,it'd be a shame (not to mention costly) to scrap the little car for such an easy fix..
Whilst it may not be too helpful sitting here,its a circa 1997 1.4 Golf engine and there are plenty of these in breakers.
I'm pretty certain you'll be able to get one similar off another car, and cut to length.
Hi.
Thanks for the postings, I thought someone would know somthing. Very useful photo. I will try asking for a 1.4 golf hose from the mid 90,s.
Since posting I have seen the post about the online spares catalogue. From that I have got a part number to ask about.
It seems to fit a lot of engines so I am suprised if it is not available.
Plenty of pattern top & bottom Rad hoses listed but not a listing for this one. Not even from the GSF online catalogue.
Self amalgamating tape, a get U home bodge, got me home!
Polo lives a little longer.
Thanks all.
rmb.
