mk2/3 Polo Gearbox Rear Mount Bolt Thread size
Need to know the bolt/thread size for the x2 bolts on the gearbox rear mount.
As in the two that mount the engine mount onto the shell to the two nuts which are welded to the underside. One of mine is fucked and needs sorting.
I cant get on vagcat this morning.
Thanks.
pretty sure they are just bog standard m8x1.25mm thread with 13mm head.
ETKA reports this to be a
M8x30 using a 1/2" or 13mm Socket used with a spring and standard washer.
around a quid from a dealer
KiZ
Yeah, finially got on it, Thanks guys!
