g40 is back at last!
well i finally fixed my blown up g40, only took 2 years! the engine melted a piston due to haveing the wrong pump fitted and took the bore with it, found a second hand motor but that was preetty tired too so gave that a full refresh. G60 injectors and a genuine £146 pound fuel pump have been stuck on as well. looking forward to getting out in it as i kinda miss the uncontrollable wheelspin/torque steer! gotta say that mk3 polos are not a good car but a g40 is a fast car for the engine size.
  • Replies 8
  • Views 1.4k
good to hear another g40 is saved!
8-)
where abouts in the northwest are you?
8-) :cool:
£146 for a fuel pump? Sounds cheaper than the £172.80 i was quoted for an inline pump!!
torque steer ftw! lol.
i,m in lancaster, pump was the best price i could get for a genuine pump, did consider an aftermarket one but didnt want to mess about with the wires etc. insured now, just need to get a a mot done and will be blastin round again :biggrin:
2nd that!
sounds good man....pics???
Jamie
quality work mate, you'll have to make a road trip and meet some of us...
so go on then, how did the piston melt? was the last fuel pump to blame? or where you running some big mods and under fuelled?
bit of both, the car is actually a genesis 1.3 with all the g40 bits fitted as the origanal g40 was twice a write off! it had done 170000 miles but was running strong but i didnt know the standard polo fuel pump is weaker, i do now! it also has a RPM tooth belt kit with a tiny pulley on the lader, dewedged, de cat, all the normal stuff done but g60 injectors too this time just to be sure.
MOT on friday night so should be on the road for weekend 8-) and i will try to sort some piccys too.
i spose its not a true G40 but the real one had none tinted glass and no sunroof, only thing missing and you gotta be a real analist to spot it is the lack of grey headlining.
