RUST! (the circle rotten kind)
I've got one of those horrible horrible rust circles that looks like an aliens eye, it actually freaks me out.
Not to mention the rust on the arch aswell.
How do i tackle this monster? Its a very very budget project so taking it to a bodyshop or cutting it out and replacing
isnt going to be possible. I am a retard so are there any pictoral guides on the internet anywhere that will show
me step-by-step what to do?
I've been trawling through thread after thread about rust but they've all been minor rust bubbles.
  • Replies 16
  • Views 2.3k
I would be interested in this too my rust is worse than yours!!
http://s142.photobucket.com/albums/r92/tomadomeit/rust/
I was quoted around £400 to get rid of this rust and i would rather just treat it and do it myself.
I'm not a body shop person but this is what I would do. whether its the right thing to do is a different matter.
This might help you with the spraying.
http://www.clubpolo.co.uk/forum/index.php?showtopic=119957
but getting to that stage depends on how bad it is. it looks like it was caused by a stone chip in the paint.
Sand it back smooth, and then treat it with rust eater or something like. If you got back to shiny metal then the rust eater might not be needed. Ensure you treat all the rust get into every nook, once it has dried, you can then prep it for painting. Primer the area with rust eating/preventing spray. do many light coats rather than a few thick ones. after the coats sand it smooth again and then you are ready for the top coat. Hopefully the guide above will help with that.
I have probably missed stuff out but hopefully it gives you an idea of work involved.
Yeah is it best to try and pick all the big bits off by hand? Because this beast will just rip my sandpaper to shreds.
Or maybe get back to bare metal with an angle grinder?
Abrasive wheel on a drill to get the rust out the bare metal,sander to smooth the damage from wheel,skim it with filler,then sand in horizontal strokes by hand with a block and medium paper. Primer/wet flat sessions,paint,holiday,polish.
get it back to bare metal maybe a twisted wire wheel on a grinder or drill then rust treat it fill and paint away :)
Lovely, I've got one of those wheels for the drill. I'll have a go at the weekend it think :-)
You need to go into the good paint 25mm from the edge of the rust to make sure that you get all of it
Freaky, I have an alien eye in exactly the same place. I intend to sand back to metal, prep it, fill etc then get a bodyshop to spray it correctly. Looking at about £100 i've been told with me doing the prep.
also, be aware that if you do your own prep, bodyshops may refuse to do the work on the grounds that their name is going on it, if your prep work is shoddy, it'll make them look bad.
^^ Yep - the prepared surface has to be perfectly smooth if the final paint is gonna be,prep'in a car is tedious. You need spaced contours,no pitting,etc.
Paint is really just a dye,even though its thicker than cling film.
Id just use a rattle can,though. Wet flat the orange-peel surface,then compound polish.
I need a big garage like that!
I'm no painter but my mate is starting to teach me how to paint and repair panels and stuff. But when your putting bodge in it should fade back into the old paintwork. Where as that one Mikey has posted the bodge still has a hard edge on it. Not like a really straight edge, but its not faded into the blue. Like you area might be small but you want to put loads of bodge in it and then sand it out. Not just put it in the area where you need it and then just sand it back.
I had a go on my sister 6N and I mustn't have took the rust back far enough and it started to come back through after about a year. I used a grinder to take the metal back as far as I could, but obviously a small amount left can just knack it.
If the car owes you hardly anything then might as well give it a go. You'll only learn if you try!
there is a metal treatment hammerite do, it eats rust and leav s a black coating and can be paited on 6 hours later, I'm using it atm and its good stuff :D
ideally it needs a gentle sandblast but thats maybe a little too much, grab a 4 inch angle grinder, knock the big bits off with that then fit a twisted knot bristle brush and give it death with that then grind again, pick any little bits out with a spike then paint with kurust, then prime n paint asap. rust never sleeps y know! :ninja:
Well i'm just waiting to hear from my dad what we're going to do with the car, it might be going to the slaughter house if its going to be too much to repair. But the thread has been very useful anyway even if i dont need to make it look better.
There's laquer in that photo too,it took a week to get it prep'd. But there was no rust visible from there (apart from where some tea-leaf had damaged the door-lock hole). All the patches are just nicks/warpage in the panels from shopping trolleys etc.
I took it at that moment as i was having a 'time planning failure' moment - it was the monday immediately after polo show. :/
