new member
ey'up people,new member from Rotherham South Yorkshire
i bought an 84 mk2 polo 2 weeks ago and havin a problem with a leak,
thought it was the sunroof so cleaned the gutter out and then put a smear of vaseline round it(thought thats where the water was coming thru)
but now i have a puddle forming in the drivers footwell
any ideas?
  • Views 1.3k
any ideas?
Ey up and welcome.
Door seals maybe?
Welcome to the forum.
mk2/3 suffer from a common problem in the battery tray which usually results in a soggy drivers foot well. Pop the bonnet, remove the battery (2 min job) and have a look in there. If it looks wet and crusty thats probably your problem right there! Realistically if its that then you will need a new battery tray welded in.
how can you tell?
will they be perished?
check the battery tray first, if its not that then take the door card off (easy job) and check the plastic membrane is still there and intact, if not make a new one and use double sided sticky tape or duck tape to stick it down, you can use binliners or something it doesn''t matter. this basically makes the water run out of the bottom of the door (check holes in bottom of door arn't blocked) instead of into the car.
you will be able to see easily if the door rubbers are perished or split mk3 ones fit so its quite easy to find a better set if yours are knackered, you call also buy it off the roll from Frost or somewhere if you want to put new stuff on.
cheers for that it was a small hole under the battery which has turned into a large hole (now bodged with a butter tub lid and duck tape until i get it welded)
small hole to weld on rear drivers side wheel arch too then ready for mot
