Removing 6N door card
Strangely all the screws fell out of the mirror and it dropped off. So went to replace them all. Popped the clips, un-did the bolts behind the grab handle but it felt like something was still holing onto the door card. Couldn't see where but I didn't want to just yark it and break it. The car has electric mirrors if that makes any difference.
Bit annoying that the screws for the mirror are behind the door card. There behind that plastic cover on a mk3!
Cheers.
  • Views 1.2k
theres a screw in the door handle hidden see if thats the pesky bastard thats keeping it on :)
I took my cards off the other week when fitting my speakers and i f i can remember i took the door pin off then the two screws behind the grab handle and then then it's all the clips, and then the electric mirror switch connector.
Cheers.
pop the electric mirror switch out if it is drivers side kam! pull back the door handle and a small flat head should pop it forward and out.
door pin needs to come off too, but sounds like you will have done this along with all the other bolts you mentioned!
pop it off from the bottom edge at the rear or the card and wirk it round, it shouldnt have anything else holding it on!
the door handle needs fully opening out to remove the card too!
