minisuperlight wheels
does anyone know if a set of superlight wheels off a mini (13x7) would fit ma mk3(1992)polo saloon or will i need hub adaptors????
Edited by supercheal
  • Views 865
Well yes and no the mini is PCD 4x4" the polo 4x100mm so about 1.6mm out, you can use offset taper bolts to fit them but it's not quite ideal.
being et -7 as well they stick out by a long way on front arches
