Metal car ramps
I hate working under cars even when using axle stands and a jack...
I was wondering if anyone uses those metal car ramps that you can get quite cheaply, are they any good/sturdy do you feel safe when working under the car?
Thanks,
Mahbs
Edited by Polo M
  • Replies 20
  • Views 2.1k
Thanks,
Mahbs
i have a set but the lupo wont fit on top of them unsure how safe they are tho
there totally safe ,dont worry
there safe mate, only tricky bit is drving up the clates and trying not to ovr shoot the top, if your car is lowered you got no chance of getting on them btw
Safe yeah, i got like 7 for free from behind an old garage, my Mk3 wouldt fit up forwards, only reverse, so doubt the 6n will get up at all lowered.
They're far safer than axle stands,and very quick and easy to use - as long as you have good clutch control.
They used to be far more popular back in the days when we had cars that could drive up them..
But since the age of big plastic bumpers and long front overhangs,many cars today (especially front wheel drive) cant get up/down them without damaging the front bumper/valance/spoiler.
I got a set cheap from Screwfix and they're great. My GT is down 40mm and just gets up forwards, no problems backwards. My neighbour's standard Mazda 323 (the one with pop-up headlights) had problems with the front splitter when he borrowed them.
Definitely safer than axle stands, as long as they have a strong enough weight rating, but useless for anything which needs a wheel off.
I got a set for free too!
They are waaaay better than axle stands and i feel much safer using them.
only problem is, you need people to hold um or sometimes when you go up um they shoot forward. or you end up flying off them, and thats gunna be nasty on the sills.
i got a set for free as well hahaa
there great for under car access....
am down 60mm all round and i get up them alrite, reverse up for exhaust e.t.c at the back
bumper off to get the front up job done :)
i got a chock for where the back wheel would be when the front wheels are up, so you hit the chock before you shoot off
i sometimes use them, i find if you place a couple of short bits of wood part way up the ramp to lower the angle then i can easily get lowered cars on.
I've never felt confident driving up them in front drive cars, might just be me though!
was thinking of getting some but then thought ...when start driving up them wont they move forward?
Not in a front wheel drive car Ninja,no.
Take the wheel to the ramp,virtually at a stop,then climb them slowly on the clutch,then let off the clutch just on the peak so it falls into the top bit.
Like i said,you need a bit of clutch control. Might be kinda tricky in an auto,I've never tried,but at least you can have your left foot on the brake.
I got a set for free too but neither of my cars will fit on them without taking the front bumper off.
try jacking car up then putting the ramps under the wheels and lowering the car on to them if you too low to drive onto em
it'd need one hell of a jack to get the wheels high enouh off the ground to fit the ramps under! My jack doesn't go high enough anyway
yeh good point the little dealership special one wont be big unuf. i got a chap trolley jack from a car boot sale that takes it up just high enuf
These are reet bo for safe working, helluva lot safer than the widow makers :lol:
Yep my car is lowered but not excessivley slammed I think I'll get a set and give it a go.
Thanks everyone for your responses.
Mahbs
Hey,even if your clutch control is crap and you do manage to pivot the ramp and thump the sills,it wont do as much damage as a widow-maker.
I've had the white nylon hub of two VW boot jacks snap on me and slam the car down.
Used to use these for certain things where the wheels dont have to come off like oil changes etc. So much safer than jacks and give you more space under the car than stands. However, if like me youre going to put a brick behind the other wheels, remember to take them up again before you try and drive off... i shot the ramps 6ft into my garage by not doing that :p
Cant use them anymore though, cars too low. Used to scrape at stock height... No chance now.
