Whats included in a service?
Probably a few people that have had the SERVICE INSP come up on the milometer. Just wondered what was included in the cost of a service, they're about £80 arnt they?!
  • Replies 14
  • Views 1.6k
Depends on mileage, if its one of the milestones it could be alot more if timing belt and stuff need doing.
Someone on here got quoted like £400+ from a dealer for a major service.
F*** me!!! I'm just over 84000k i dont no what that'll mean for me. I've been having suspect idling problems pver the past week or so though so I'm a little aprehensive! I've read all the posts about cleaning the throttle body but dont really have a clue what to do there so might leave it up to the service?!
Got any service history? should've had a big one at 80k.
Ill check my log book, i bought it at 74,610 so i think the last one might have been 70k but dont hold me to it. After reading a few threads I'm thinking about doing it myself i dont fancy being bum-fiddled by a garage with their prices! From what i understand a basic service is oil, oil filter, spark plugs, top-up and coolants?! Had a new 'performance' panel filter about 4k ago so that wouldnt be neccessary would it?
Changing the oil, filters and plugs is only a basic service on the engine. The service light will need resetting by a garage/mechanic with suitable equipment.
A proper service includes checking over the suspension, brakes, wheel bearings as well as other sundries too. If it's not been done recently, get the coolant and brake fluid flushed and replaced too.
You will not get a service for £80 at a garage, at least not a half decent one.
Not on a 6N
Can be reset by holding the trip counter button down and turning the ignition on and off
http://www.clubpolo.co.uk/forum/index.php?showtopic=174
:-D
I had a service a few days ago with a VW specialist (not officially VW) for a milestone at 50k and they qouted me £65 (thats without parts) turned out that i needed a new timing belt and spent £300 :shock:
I think you were probably better off doing it yourself?! I dont know whats up with my polo but today it started revving upto 3000rpm on its on accord i looked a right noob sitting in traffic! Anyone know what the problem is :s
I just did a service on mine - plugs, oil, oil filter, air filter, cabin filter, coolant check, cleaned throttle body, visual inspection of brake pads and shoes. It normally costs me about 45 quid in bits from GSF. It'll have the brake fluid done by someone who knows what he's doing along with a pre-MOT check soon (including inspection of things like bearings, bushes, etc). I did dizzy cap and rotor arm at the last service, and HT leads will be done at the next one.
Basic stuff can be done at home, but I always hand it over to someone for the stuff I don't know about.
What do the numbers related to oil mean? Ie 10w40?! what would i need for my 1.6 6n (AEE i think) Do the numbers make much of a difference?
do it your self and reset light? oil, oil filter, airfilter, discs and pads and quick inspection yourself all info is on here or in haynes manual to do it?
The numbers on oil are to do with the viscosity (!) of the oil 10w 40 is a standard blend. it will tell you in your manual what oil you need. It needs to be right as it stops the engine from ripping itself apart (it lubricates everything).
As for a service you can do a short service yourself oil and filters. The big services you need to got to vw, a specialist or a very good garage to get the job done, as they can reset the service light (although for about £60 you can get a piece of kit that will do it for you DIY style) and give the brakes and cooling system a good once over, do all the hard bits (cam belt).
good luck
Don't forget the wash & valet and the wonderful coffee I get at my local VW garage..............:-)
always use genuine parts IMHO, parts for MK3/4 Polo's are so cheap now from the main stealer, why risk using inferior quality parts????
While you're there, save yourself some money, get a jack out & check the wheel bearings & bushes yourself, save yourself a PRE MOT inspection fee.......or save yourself time & just chuck it in for an MOT. Make sure you get a free re-test & if it fails just get whatever done at the time.
I never have had much time with "Pre-Inspections" unless it is the actual tester looking at the car, as he could spot something completly different and then you've wasted time & money...............just my 2 penneth
