rumbling noise
i hear a low rumbling noise when the car is running and the gearstick is in neutral (manual car)
the noise goes however when i press the clutch. is this a real problem and what is there that i should do to fix this.
I also hear a much louder rumbling when driving in gear but not giving gas. as soon as i give gas the noise goes.
to me it sounds as if something is loose however i really have no clue.
Any suggestions will be really appreciated.
  • Views 969
Sounds like it could be the clutch release bearing on the way out to me
would be a gearbox out job to repair
Right so nothing i can do myself then. how much does it cost roughly?
what car have you got
its a manual 6n2 mk5 (51 plate)
