Instrument panel lights don't work!
Hey there,
Basically all the lights have stopped working on my instrument / control panel. The lights arn't working around the heater controls, cigarette lighter and on the actual dashboard. So at night i can's see how fast i'm going, or how much petrol i've got... which ain't great.
The actual blowers still work, as does the radio and reading light.
Any body got any ideas what it could? Guessing it's a fuse, but i'm not 100% sure.
Any suggestions would be much apprciated.
Rich.
  • Views 931
fuse would be the first to check but if not could be the bulbs or if they have it the dimmer switch under/ on the headlight switch
Definetly fuse, carnt remember which row there on.
The lighter,radio etc are seperate. The dash lights are connected to the side light circuit,so are all the side lights working? You may find the ones only on one side work,and that'll be the fuse.
If all the side lights work,and thus the fuse is okay,then it could be the rheostat wheel/switch itself,or wiring to it.
But its definately the rheostat circuit,which is powered by side light circuit.
