Polo GTi
Ok so I went to have a look at a Polo GTi today, Black full leather electric sunroof fully loaded.
The thing that bothered me was the wheels they were the standard BBS rims v nice only the outer edge was badly damaged/ crazed, I could only see 2 of the wheels as the guy selling the car had painted the other two. He said this was normal !
I also noted the clutch and gearbox I knew it would be different to mine because of it being older and high performance, the box was quite clunky and the cluch was v heavy.
I like the car so can you guys tell me if these thing are normal / correct
Thanks :thumbsup:
  • Replies 11
  • Views 1.4k
my standard alloys sound exactly like yours. flaked round the edge and generally looking in a sorry state. This is usual i think for these wheels.
My gearbox is fine (40k on clock) but they are renound for going. My clutch is fine to me but i think I'm used to it as my dad drove it yesturday and said it was very heavy. again i think thats just how they are.
how much is he asking for the car? what mileage has it done?
which model GTi?
good point, i was on about a mk 5 (6n2)
Yer it's a MK5 5 door Black 57200 £4000 one owner from new. It's nice
With that mileage, the gearbox is likely to be nearing its first demise!
As for the alloys, yes, its a regular common fault with corrosion.badtimes i know...
other than these, look out for spoiler paint bubbling and corrosion of the rear boot handle as these are also common faults.
It is prity mint other than alloys gearbox and a few paint chips.
Dont get me wrong, it sounds a good price for the mileage, andblack can look awesomewhen kept clean. But if you want to avoid further bills, be sure your comfortable with how the gearbox feels as a recon is likely to push you to + £300 or a new one £800ish
And if you do end up going for a Gti, then regular change of gearbox oil will give it a longer life:-)
It's the fastest car I have ever driven and I now have a bench mark as I have two more GTi's to look at tomorrow.
I've clocked up over 100k miles now with my gearbox and it is absolutely fine :thumbsup:
Notchy gearchange (when cold, much better when a bit warmer) and a heavy (ish) clutch is normal, as is the "looseness" of the 'box, that is to say that when in gear you can wobble the stick left-right quite noticeably.
The corrosion on the wheels is also normal for the standard BBS rims - unless they have been looked after and kept clean they will always go this way as dirt and grime (esp. salt) works its way in and eats away at them.
Boot handle corrodes easily because it reacts against the different metal of the boot! Annoying, but fact. Mine needs sorting out :smirk:
All of them are notchy, you get used to it. Replacing the clutch is a winner. Corroding boot handles suck. I got mine repainted last summer and it's a state again :(
My spoiler has started to bubble, just looks wet un the underside of it all the time lol
and my handle is starting to show signs :-( bad times
Its a good thing i love the bloody car haha
