Anyone got a brake bleed kit in Huddersfield?
I changed my MC and lines before i came back to uni, and i think theres still some trapped air in there as the pedal sinks very very slightly on hard use. :lol:
So if anyone has one? Otherwise I'm going to have to make one pikey style...
Cheeeeeers
Ash
Edited by carver
  • Replies 10
  • Views 1.5k
cheapo ones are like £4 from halfords
all you need is a see through bottle with some brake fluid in it and a piece of rubber pipe to fit over the bleed nipple.
Then either a friend to pump the pedal or an eazi-bleed kit.
got one in leeds mate.
will cost more in petrol than to buy one!
cheers will look in halfords for one, i need some sort of suction like a big syringe or something...
Anyone see any reason this wouldn't work quite well?
Ebay: 370097019358
Link
Edited by carver
EZ Bleed is only something like £13 from GSF. Useful thing to have knocking about imo.
Is that the one where you use a spare tyre for the pressure? They anygood and more importanly easy to use on a one man band?
Thats the one. You don't need a second person to help, can just do it yourself.
I'm sure you could make something cheaper but I'd rather just pay the £13, which isn't a fortune anyway and have the proper thing.
Sorted chears heartagram
My easi bleed dislodged its ball bearing and filled the system with air,so i binned it and had to find something there and then - just a bit of airline pipe,long enough for me to hold from any wheel. Clip it on the nipple,and use my thumb over the end to open and close it. Works brilliantly.
the whole point of an eazibleed is that you can do it with one person. If you have a spare person knocking about then all you need is a see through bottle and a piece of pipe, then get the stand-by person to pump the brake pedal slowly while you have the bleed nipple open until no more air bubbles come out.
