MK3 coupe boot leak
hey guys
Got a small amount of water in my boot and can't find where its coming from!!!
there is no moisture under the clusters, no moisture on the internal part of the boot seal, and no rust holes!
anyone got any ideas where its coming from? or any ideas how i can get rid of it!
Considering drilling a few drainage holes in the boot to sort the problem short term.
Mike
  • Views 1.8k
i had a leak in my boot need i took the bumper off need there was a little crack need i siloconed it need problem solved
No need to drill holes as theres 1 either side behind the wheelarch & 1 in the spare wheel well. Remove the boot carpet & everything else absorbant for a while so you can see where its coming in.
As above post the seam behind the bumper is a common spot.
The rear light seals are another.
Are the seats getting wet? If so then its the hatch seal.
Mine had a leak between the glass & the hatch which i had to reseal.
Can always get someone to hosepipe the car while you get inside with a torch to have a look
I've had 4 polos now, 2 being coupe's and all have had leaks!
i get a pond under the rear bench seat, and a mini lake in the boot.... right next to my amp... BAD TIMES!
could be the boot seal
make sure the drain holes are clear
Think i've found where its coming in!
I've put a small amount of silicon on the bumper bolts and haven't had any puddles since and its been raining hard! Just not looking forward to changing the bumper, which may be soon
I re-sprayed mine recently,and found on stripping that its had a tap in the back. So we gave it some jig action.
But now the boot leaks. I've used talcum powder and still cant trace it,the cars like a cold sauna.
Theres a seam where the floor joins the back panel & the bumper bolts pass through. This seam doesnt have seam sealer only paint, so in an old car it leaks. Water seems to pass through the bolts to.
Worth sealing this seam & the bolts if youve tried everything else
