MK2 grills
hey guys
hopefully should be getting a twin headlight grill for a friend of my GF's (she's helped my GF out in the past and i want to do something to say thanks)
so basically i want to upgrade her grill to a twin headlight grill.
bodywork question - will it just fit in?
Lighting question - how hard will it be to fit the second set of lights??
Thanks,
Mike
  • Views 1.5k
should just swap over....the cables should be hanging around somewhere
15 min job with any luck
nice one, are the second headlights hard to pick up?
yeah stuff comes up on the forums
be easier to look for a used grille with the lights inc
Thanks, managed to pick up a grill with lights and part of a loom, had a look in the engine bay and couldn't see any additional wiring. The loom that i've got has a black and green wise on it, where does that go? Is it for fogs? Sry if i sound dumb, never looked into a mk2 before.
Car is 150miles away so may be a while before i get to see it again
My very first mk2 had the connections to plug in the spotlights, no problems... however my second mk2 didnt have that part of the loom so i couldnt connect the new spotlights
Yeah I think it depends what model mk2 you have on whether the connections for the extra lights are there. I've got a coupe s and the connections are hard to miss, when you put the twin headlight grille on the dangly wires from the extra lights line up pretty much spot on to the connections.
Its an easy job though, my single light grille has no screws just the clips and I think theres 2 screws on the twin light grille. I'm always changing them as I can't decide what I prefer.
