Mk2 Bread Van.. Advice please.
Hi Guys,
Just signed up, I have been driving around in my Mk3 Gti for a while now. I came across a really good condition White MK2 Bread Van (I think thats what they are know as?, perhaps a square back?).
The golf drinks fuel so was thinking about picking up the polo to run around in as it will be cheaper? Then sell the golf.
Its a 1Ltr Match, with years ticket and 45,000 on the clocks.
I just want to know if there is anything I should look out for and what are they like to live with?
Thanks in advance for any pointers.
Drew. :-D
  • Replies 9
  • Views 1.7k
Hello!
The carbs can be a bit gay on them if it still has a peirburg one on. But it can be upgraded to a webber which is better. Look for rust in all the usual places you would when buying a car but also pull the battery out and look in the battery tray. They are prone to going in there, you'll know about it when you have wet feet! If its gone you will need to weld a new tray in, which if you can weld isn't to much of a problem. But if you can't you'll have to factor that in. Also the necks of the petrol tanks have a tendency to leak. Again, its not expensive to replace if you can do it yourself, but will be quite expensive if you have someone else do it. Tanks are around £60 IIRC.
I don't have a huge mk2 knowledge but they are the things I know that go wrong on them. Just look for rust in usual places, along the sills, bottoms of the doors, arches, lower valances etc etc.
Cool cheers, I have a Mk1 Caddy as well so recon it will share most of the same rust problems they have.
Been looking in to it a bit more, think the 1ltr engine is the sticking point for me, I like having some power at my feet and think i'll end up thrashing the polo and use just as much petrol!
Yeah it will probably be 4-speed aswell which can be a pain in the arse for everyday driving (for me they are anyway!) Going along the bypass at 60mph in 4th and its making loads of noise ergh
Are you the drewcole off fensdubbers? I think i bought my alpine amp off you. Polo sounds like a good idea to me heartagram has pointed out most of the common problems 1 other thing is if it has a sunroof check it for leaks as the seals are a bit crap.
I've just bought a MKII van, and so far haven't had any shocks.
They seem to be prone to surface rust, haven't found any real rot on mine yet. Worth having a look for any, as mentioned above.
I always heard the Carbs could be a bit dodgy, however i have now had two cars with Nikki Carbs(a suzuki + nissan) and this carb is heaven. Although i'm still a little dubious about the autochoke actually existing atm.
Mine is a 4-speed as well, isn't really causing alot of hassle for me. But obviously long trips could be a little annoying, or with a larger back box that might be a different story!
Edited by Zach
If you want a bit of power you could always convert it to a GT. 1.3 Multipoint with 75bhp. Not going to set the world on fire but they are nippy for what they are.
Yeah thats me bud, I had the Mk2 Caddy van with the checkered bonnet and Lee (caddyrages) old wheels, sold that now (wish I hadn't) so got the Gti.
This one has some minor surface rust on the drivers seal but i've checked that out and its only just surface, so would rub out and could be sprayed back in with no trouble at all.
Just think i'll miss the power to much......
Yeah thought about that, a G40 would be good! but don't really want to mess around with engines that much.
Kinda just want to get in a drive!
You must check the fuel tank filler neck and the bodywork round that area plus all the inner arches..
Check below the battery if you can because it's another bad area for rot because leaves and shit get in there and trap water.
check the front end slam panel etc. because stone chips can cause bad rust and also get your head in the bay and check the general rust/integrity of the box sections. I have bad rust where the water washer bottle was leaking.
As for engine, service, service,service! HT leads, swing arm, plugs, clean contacts on coil, it goes on... The 1L i had was more reliable than my current 1.3 and off the lights was really nippy. It would also cruise on the motorway no probs. Yes there is higher revs with only four gears but most of these cars have long gear ratios to compensate.
Clean/service the carb and get an understanding of how it can be adjusted. Service the brakes(better pads can improve things) or steel the vwII ones off your caddy lol. theres loads about upgrading on here(use search engine).
I have a weber on my 1.3 which deffinately has improved performance/reliability. The next thing I'm doing is fitting a g40 brake upgrade then either a gt exhaust manifold or stainless four branch to add a bit of breathability to the twin choke carb upgrade. I don't know about 1L upgrades with carbs? I might aim to go 5 speed eventually but thats more work...
Finally and importantly check the head for oil leaks (especially above the alternator) this could be a sign of the head gasket going which isn't nessicerally the end of the world if your handy with spanners.
Also don't expect to bolt on wide offset wheels like wellers because you'll have to mess with the rear arch. I'm sticking to oem+ wheels 13" or 14"(with the right tyres) 6J max.
Good luck
Cheers Dunc
