Polo GTI 6n2
Hi I'm a n00b here, I'm looking at a 2000 Polo GTi on wednesday and was wondering what things i should look out for?
this is the ad
93,000 miles, VOLKSWAGEN Polo 1.6 GTi 2000, Black, ABS, Air conditioning, Alloy wheels, Body coloured bumpers, Central locking, Drivers airbag, Full service history, Xenon headlamps. Comes with original VW roofrack & all fixings. 93000 miles. A great car in fine condition, genuine reason for sale (we're relocating overseas). Comes with original VW roofrack plus all necessary fixings
My friend has a lupo and has told me to look out for/check the:
Central locking
Cambelt and waterpump should have been done twice (every 40k miles?)
Gearbox, check it doesnt whine or hard to get into gear
Xenons - good nick because they are expensive to fix
Pedal box - make sure its been replaced?
Any other help would be much appreciated
  • Replies 11
  • Views 1.8k
Looks like you've got it all covered, I woulda just said, make sure the gearbox isnt whining, ask if the car had been recalled for the pedalbox, and check to see if the cambelt had been changed. Also dosent hurt to have an HPI check on it, to see if it was ever written off :lol:
Cheers mate
I've been told there will be a sticker to say if the pedalbox has been replaced? located in the boot iirc?
the standard alloys are prone to corrosion. mine have and only 40k on clock
I think they may be slightly corroded, i can see it from the picture
If i were you i'd check that the gearbox has been replaced or at least had a recon at around 60k.
The wheels are a common fault to corrosion - a couple of hundered to get them fixed up.
The pedal box was a recall from VW - it should have had this, although if not you can take it down to a VW dealer and they will sort it out - i had mine done last year because it had never been replaced.
other than that I'm sure everything else will be pretty fixable, or you should be able to get some cheap parts.
If i were you though, id go look at more than 1 GTI, just so you can compare them. :thumbsup:
where are you looking, mine might be coming up and its a minter to say the least!
Cheers for all the replys :)
hollypop - thanks, if the pedal box hasnt been done its good to know its easily done (for free?) at vw :)
dubbys - let me know some details mate, i might be interested
mouse - cheers mate, those guides are really usefull :)
No problemo :)
Yes it was free! ;) mine wasn't even a GTI either.. but has the same part number as a GTI so i just argued untill they agreed to do it
Bought the car last night, was a very good example :)
Everything was fine bar drivers side window is a bit sticky but ill take that appart and give it a re-grease (if thats needed?)
Really happy with it, ill get some pictures up tomorrow and hopefully come to a meet if they are local to me :)
Cheers for all the help guys
