Removing 9N Polo badges
Hi guys,
I have a black 2004 9N Polo
I'd like to spray my Polo's badges but have no idea how to remove the rear one from the bootlid.
I've been told that I have to strip the inside panels off the bootlid and then unscrew the rear badge, is this correct?
The front one looks pretty straight forward.
Any advise will be appreciated.
  • Views 1.8k
the back just pulls off but be carefull as they sometimes snap
the front will need teasing out of the grill. if your not doing tham black you will then need to seperate the chrome part of the badge from the blackplstic bit., abit poking with a small flat head is all it takes
hope that helps
Edited by S23 CLY
Thanks mate.
I am doing them a candy apple red.
I have sourced a spare original front badge to test with.
Want to see how it looks before I make it a permanent feature on the car
nice to see someone mixing it up for a change
although i admit i am a black badge sheep
Thanks mate,
Everyone here in South Africa is going black badge now.
MK 1 - 5 Golfs are either de-badged/black badged.
Most Polo's and even the odd Corrado if you can find it.
I want to do things a little differently with mine.
Will post up pics as I go along.
Sheesh, getting hold of the Candy Apple colors is proving to be a bit harder than I thought :(
Not a popular color in this country so most places don't stock them.
I am gonna try a few Hot Rod places to see if they can sort me out.
wooooo i sprayed mine black lool. gues u dnt like it like that.....
its soo easy 2 take them of.... just use like a butter knife need peel the bak 1 of.. need the front comes of liek 3 clips on the back...
good luk with the rest of you are car
