Wiring diagram for mk3 fog light
Alright. ,
Looking for a wiring diagram for a mk3 polos fog light and switch. Any help much appreciated.
  • Views 1.2k
The haynes manual is @ the top of the engine section
not got round to getting the Haynes manual and probs wont be able to till the weekend so.. If all else fails thats where i shall end up.
Cheers anyway
Edited by Swize
Its free to download using the link
Basically:
There is a connector by the ECU under the scuttle tray, think it's one brown cable and one white and or yellow cable with a connector on the end.
That cable is for your front fogs, get some connectors from a scrapyard and you can make your own loom up pretty easily. you need two cables, one that runs from the connector to the offside foglamp then a cable from the nearside foglamp that joins onto the long cable.
Edited by martinb
