mk1 polo derby
  • Views 1k
Just looks like a Derby that was fitted with a pair of twins before crashing into a barn and being left there for the last 20 years.
bit rotten in places but would be good for a restoration project. Would be even better in RWD !!!!
It no stock engine, probably a real screamer probably easily over 100bhp if setup well
1. Unterbau zerlegt, komplett überholt 1st substructure cut, completely overtakes
2. Motorblock geplant 2nd engine block planned
3. Zylinderkopf geplant 3rd cylinder planned
4. Verstärkte Kopfdichtung 4th Enhanced head gasket
5. Ventilsitze geändert 5th valve seats changed
6 Verstärkte Ventilfedern 6 Increased valve springs
7. Schwungrad erleichtert 7th flywheel easier
8. Schwungrad gewuchtet 8th balanced flywheel
9. Verstärkte Ölpumpe Enhanced oil pump 9th
10.Pleullager 10.Pleullager
11.Hauptlager 11.Hauptlager
12.Scharfe Schrick 280° Nockenwelle 12.Scharfe Schrick 280 ° camshaft
13.Verstellbares Nockenwellenrad 13.Verstellbares Nockenwellenrad
14.Weber Doppelvergaser 40 DCOE 14.Weber double carburetor 40 DCOE
15.Sorg Ansaugkrümmer 15.Sorg intake manifold
16.Sachs 3 tlg. HD Kupplung 16.Sachs 3 tlg HD clutch
17.Wasserpumpe 17.Wasserpumpe
18.Zahnriemen 18.Zahnriemen
19. Mocal Ölkühler (hinter Stossstange verbaut) 19th Mocal oil cooler (behind push rod installed)
20.Pierburg Benzinpumpe (95Liter / Stunde) 20.Pierburg petrol pump (95Liter / hour)
Tatty body + banded steels + decent engine = me smiling.
