GTI compression stuff
hey fellas,
its your rindooshbag here, asking another question:
anyone ever had their head skimmed before?
i think that when i get paid tomorrow, ill have some money! which is nice!
id love to get a bit more power from my ARC-GTI motor, and thought about bringing it to a machine shop, and skimming the head for higher compression.
question is.. how high can i go (ratio wise) before i should start worrying about reliability?
what is the stock compression rate anyway?
any help?
for people who have had this done to their car, was there a difference? any issues? changes?
I'm curious:)
  • Views 820
hey fellas,
any help?
I'm curious:)
Wow wow, watch out with just going of and skimming your head mate!
By skimming it, well yes you increase your engine compression ratio in the top-dead-centre = higher combustion = more power, BUT!
If you skim your head say 1mm, the distance between you cam-pulley and crankpulley deacreases, making the position of the cams in comparison to the crank alter just a couple of degrees, resulting in "non-optimal" timing of your cams&ignition. So in order for skimming to give optimal results, get yourself adjustable cam-pulley(s) in roder to keep the cam- & ignition-timing in optimal order, for optimal performance!
Also how high an compression in TDC (top-dead-centre) depends on many factors, one of the most important ones is fuel. Fuel may look/smell/costs almost alike, there's a lot of difference in quality though. The cheap stuff from the self-service Tango or TinQ is crap! It will pre-detonate before TDC at high revs when on a too high an compression. But for instance the better quality BP Ultimate will start to pre-detonate at higher compressions due to the higher octane-level and "cleanness'/"purity" and therefor quality of the fuel
But if you wish to tune your ARC, let me know, I know just the perfect address for it, ever heard of that mk4 1,8 20v bi-turbo on throttle-bodies pushing slighty over 500BHP here in Holland? 8-)
Easier and cheaper ways to get more power. As i've suggested before de-cat and remap you'll be entertained for a few months.
