Golf gti afm and airbox for gt
I am selling my golf gti afm and gt airbox.
The airbox is drilled, but only on the front, so wont suck in hot air from inside the engine bay.
This gives you the extra airflow of the gti afm but looks factory :thumbsup:
I'm after £35 would consider postage but its quite large
I'm based in cannock, Thanks for looking
  • Replies 15
  • Views 417
Pics soon
how have you fitted the gti afm to the gt airbox?
theres a thread on here somewere by Gaz that tells you how
i may have a link on my home computer..... i'll PM you it if i find in
FREE BUMP :thumbsup:
yeah please! I know 86c did the same but I'm sure he said he used part of a golf box too..
Lucky for me this chap did it to his before i bought it off him.
bump
I had a look at fitting it last week to the GT box and looked like to much effort for a sunday, hows it done? Cut the plastic out with new and JP weld?
Yeah cut out the required dimensions and you can use a few things. Mines been fibreglassed in to give a smooth finish on the inside
Hey, will this wire up and run to the GT loom with no problems? Not going to have any problems with the ECU being confused or anything?
You dont wire it up?? You unscrew the Polo one and replace it with the GTi one - then tinker with it so it runs properly on the GT.
It must wire up some how to send signals back to the ECU?
Yeah its just plug and play. Disconnect the gt one and connect this one. It was set up on my gt so may run perfectly on yours, but may also need a little fiddling. I can help you doit if you need me to :thumbsup:
Great, is it ok to pick up Friday evening sometime? I'll be passing by cannock on my way back home.
Yeah thats ok, ill be in from 5 :thumbsup: PM me your number and ill send you my address
Edited by shaun_89
