G40 High Lift Eaton Cam
Brought this from Lance a while ago but I've never got round to fitting it and as i'll be getting another one very shortly, i might as well sell this one.
I'm not too sure on the specs but will increase top end. I think its a PSD cam but will try and find out.
Fits G40 only.
I'm asking £60 for it + £5 postage.
If you need a pic of a camshaft, you need to get out more!
PM me for more info......
Edited by vwmk3jon
  • Replies 23
  • Views 827
If you can find out the lift/duration I'll be interested!
i am not sure but it could be a eaton spec one so if your running around a bar boost it'l help alot!
cheers mate :thumbsup:
up
hey jon,
did you find out if its a psd one or not?/whats the duration/spec?
Cheers,
Juan
i'm 99.9% sure its a PSD item. Was told it came from there. I'm not sure on duration/spec as i haven't any paperwork for it.
hows the eaton conversion going btw?
eaton conversion is going good just waiting for a nice package to arrive :), and just gathering random bits and bobs.
ill only be running my eaton on a standard engine as i can't afford a full blown monster plus i want to get the handling sorted. But if in the future the engine does give up id like to turn it into a 1.5 :) (money permiting)
Edited by juanv6@hotmail.com
moneys the only limiting factor! lmao. I'm spending all my compo money on mine (£5k) as it deserves a rebuild.
Bttt........................
will it only fit a G40 head. what about a 1272 head, I'm using an electric pump anyhoo etc.
AFAIK, its G40 specific. It might work with your car but i'm not even 50% sure! Best to ask in tech section.
i'm 99% sure it would fit Julian!
it;ll fit any 1272cc head but it wont be suitable for an NA engine if it's a G40 cam. You could do with finding out some specs for it though mate, any part codes or serial numbers on it? £80 is a lot of money to gamble on a cam that could be anything!
it will have a stamp saying pg3 or something i think mine has one dont know thw lift an duration though
is that if it's a PSD "eaton" cam?
hmm tempting, ye but 80 notes for a cam isn't bad at all.
even if its ment for forced induction shudn't matter if i stuff it on a bike carbed 1300 with a polished head...
i've had a looksie at the cam but cant any item numbers etc on it. It was sold to me by Lance so he might know where it came from. I was gonna use it on my G but i just haven't got round to fitting it! pics to follow..........
does anyone know what duration and lift the PSD 1341cc ones has?
I have a way of measuring this on a cam therefore i can find out what this cam is.....................
it all depends on what the specs of the cam are but generally speaking forced induction cams are no good in naturally aspirated engines. Quite often FI cams are milder than NA ones. Boosted engines don't like lots of overlap whereas NA ones do. But as I said, depends on the actual specs of the cam.
Robin - As per our PM's, I'll send you the cam if you pay postage?
am sure its a eaton spec cam if you have a look on the side that the dizzy goes on if should say pitstop p3 or summat like that i think
cheers mate
BUMP NEW PRICE. TAKE A GAMBLE!!!!!!!
SOLD :-)
