mk2 glove box keeps dropping...anyone made a fix for thiers?
i find the back edge off the mk2 glove box keeps hanging down due to the naff design
just wondering if anyone has come up with a fix for this , as its getting on my boobs now
  • Replies 12
  • Views 1.9k
Cable ties. Drill some holes in the back bit of the glove box and then loop them through the hole where the glove box normally locates and thats it :)
Cable ties, or failing that, do what I do, take the f**ker off, thereby actually giving your passenger some legroom.
hmm didnt think of cable ties
i was thinking maybe a bracket screwed near the relays and then to the glove box
mines screwed through from the scuttle, not ideal but isnt going anywhere, the standard hook at the back is in totally the wrong place, strange.
If you remove the glove box then look at the back of your glove box and you should see were it has broken from. All you need to do now is drill a hole were it has broken off .Then look under the dash, there you'll see the round holder were the back of the glove box went into. Put the glove box back into place. Look and line the two holes up and put a long enough nut & bolt through the two holes together and tighten the nut and bolt which will hold it in place and hold it in place.
I can get you pics if needed !
Been there and it is so annoying!
I found it was the fact that I had too much in weight on my last mk2, now I just hardly keep anything in there.
If the storage below the steering wasn't so handy for CD's I would just remove that and the glovebox because it does create more room.
Above^ seems like a solution or cable ties for quickness.
I wish I had such a trivial problem with my car rather than the brake fitting and coolant/oil loss i've been trying to deal with lol.
lol man iv got the same problems man il have to try cable ties
yeah put up a pic please mate...not quiet sure what youre saying
ok some pics
remove the glove box and look at the back and you should see where it has broken at the top where i've drilled the hole in the pic
Look under the dash and you'll see this round bracket
This is where you'll be feeding the nut & bolt through the two holes to join them together
Remove the top of the glove box so that you can tighten the nut & bolt when putting it all together again
Drill your hole as near to the broken bit (the top hole in pic)Picture023.jpg
Edited by a.polo.13
then put the glove box back up to the dash
then feed the nut & bolt throw the two holes
you do'nt need to tighten it to tight then put the top of the glove box which just slots into place and all you need to do is to put the two screws in the front that should be job done.
just make sure that your bolt has a big enough head on it or just use a big washer so that it doesnt fall through or youll need to start over again.
Edited by a.polo.13
nice one thanks...i'll give it a go today
had a look and mine doesnt have that metal tab hanging down??
I've managed to bodge it up somehow tho lol
