alloy fuel tank (fits in spare wheel well)
bought this a little while ago for my derby as replacement for its tiny fuel tank
it holds 9 gallon
billet alloy engraved screw cap a
designed to use with mk2 rocco/ mk3 polo lift pump before the inline main pump, you will need to get an alloy plate made up to fit to the bolt pattern (see picture)
looking for 135 quids
located in bracknell, berkshire
k
07769697787
some pics from previous owner and pics to show its size outside the car
comparision picture is against 15" 195/50/15
  • Replies 8
  • Views 752
who is it made be? and will it fit a mk1 golf? cheers. gaz
is it baffled or foam filled?
nothing filled, you can put in your own foam or plastic netting (like the ones you get for srubbing your back in the bath
no idea who it was made by, but if your mk1 golf's spare wheel welll takes a 15" wheel with 195/50/15 tyre (see pciture) then it will fit
still available
still available
still available
Does it come with all the extra fuel pipes, if so ill defo have it!!!!
its allready sold mate i bought it yesterday sorry
