Door mirror controller problem.
I've got a K reg. Polo Fox and yesterday I noticed that the driver's side door mirror wasn't positioned correctly but when I tried to adjust it using the controller knob it would barely move the mirror at all.
I'm a complete novice when it comes to cars (was pleased with myself for changing the windscreen wipers yesterday :roll: ) but am willing to have a go. Has anyone got any idea what the problem is and what I can do about it? Thanks.
  • Views 1.5k
Hey, welcome to the forum.
It's most likely that the little controller wires have broken. My mates mk3 is the same. You can just position the mirror by hand :)
that's the cheap fix anyways! haha
Paul.
Or if the cable isnt broken, pull back the controllers rubber suround & spray in some wd40 followed by some spray grease or oil. Using a spray can with a straw, spray the back of the mirror glass. Oil may drip out from the hole under the mirror plastic surround if you over do it.
This should free it up
Thanks guys.
They do seize.
There are three cables in the cable,thus the remote and glass are on a tripod contraption. All three on my driver side are free but one of the passenger ones is stuck fast,despite being soaked in oil end to end.
