doofy failed the mot!
hey all went for mot today and this is what it failed on:
failiures
rear light not working offside,
no reg plate lights working,
hole in offside floor front,
no headlight pattern on nearside,
exhaust rubber broken (centre),
tie rod nut damaged offside,
both front brake flexi pipes split,
front brake hose seriously worn,
nearside front shocker has negligable damping effect,
advisories
severe oil leak,
n/s outer sill scabby
if anyone has any nuber plate lights going beggin please let me know pm me or give me a bell 07512288277
cheers guys
  • Replies 29
  • Views 3.8k
Did you not think to check the lights before getting it MOT'ed?
lol, mines due for the MOT soon and i already know exactly what its going to fail on as I've already done my own MOT test on it lol.
Other than emissions obv.
lol its alright for some people that actually work in a MoT test station isnt it :ninja:
You work in a MOT station?
Edited by B-shaw
by the way mate. your offside sidelight and number plate lamps work off the same fuse. probably why they dont work. or could just need new bulbs. its fuse number 4 and its about an 8 amp or 10 amp. hope this helps mate
yes mate. its brilliant get all sorts of shitty french cars and fords in lol. drove a honda s2000 out of the garage today it was lush :)
Wow, that car sounds fucked!
Go to any motor shop they'll supply you all the bulbs... don't bother asking on here, it's just a bloody bulb after all, probably about 30p each...
jesus
not much to put right then...........
all pretty easy jobs though minus the welding stuff
Bulbs.. pennys,
Tie rod nut.. its a nut,
brake lines easy enough,
shock.. easy if you can get the bugger out,
exhaust rubber pennys.
All simple fixes tbh apart from welding, though it shouldnt be hard if you know how..
yeah they all worked before i left!
thanks veedubfox it was the fuse and for everyone elses info the car isnt 'fucked' mentioning no names........ and the shock came pout a piece of piss.
jobs done today:
both front shocks changed to gmax with 40mm springs,
both flexi pipes changed,
both copper brake pipes changed,
all lights working,
exhaust sorted
changing nut tommorrow,
bleeding brakes,
fitting rear springs,
and welding the floor
and i pick up my new wheels on saturday 15'' team dynamics split spoke 5 spokes with good tyres for 40 quid
and thanks again to veedub fox
Sounds like good progress. Just worth bearing in mind that the steering rods nuts aren't a standard size, I've had to buy a whole rod end in the past to get a nut that fitted.
its ok mate i have a nut to put on it just ran outta light and couldnt be arsed
just a few pics of the work I've done
at the MOT station
and back at the workshop
Edited by nickomk1
nice one great progress! I love threads like this. :)
I like how most people who posted after the initial post acted like this youth was completely useless because his car failed on some simple bits, then it turns out he's pretty handy... book, cover, judge...
Nice one mate, seems like you're a lot more motivated than me! haha.
Cant believe thats considered a 'bad' fail lol. These polos must be better than i thought.
When I bought me second land rover I took it for MOT and got a 3 page fail sheet and two pages of advisories. Took me a while to sort that lot out. All for prop UJ's, 3 wheel bearings, Front swivel bearings, rear brakes, hand brake, corroded brake pipes, leaky injector, front diff leak, 3 bent rims, 2 cut tyres, Sharp edges on bodywork, front radius arm bushes, front panhard rod bushes, rear trailing arm bushes, rear A frame ball joint. 2 rear leaking dampers, etc etc.
'youth' I'm flattered. lol. i try my best with bodywork and mechanics but i just cant weld but as I've said before this is my main project
why I'm rebuilding it:
what it looks like at present (at the same bodyshop as the polo)(under the sheet in the background)
and hopefully what it will look like when its done but red not blue
the polo is being re tested on friday and taxed so i dont have to walk or drive the missus 206 anymore woohoo!!!!
that blue fiesta is amazing! I'm not surprised you want it to look like that :)
Good luck for the polo's re-test.
I wouldn't say it was a bad fail really, mainly just brake bits which are to be expected really. Welding is the only problem but I had to do some welding on my g40's sills just before it's last MOT.
Sweet fiestas!
Sweet fiestas!
update: all jobs done all bar finding the oil leak which is a big one and I'm not kidding all i know its not comin from the rocker cover gonna get it re tested 2moro, get it taxed, and get the engine bay steam cleaned to try and find the leak. ill post 2moro
hey nicko, whos is the bay next to the fiesta? bring on the air cooled :nod:
good luck with the mot burt. i'll drag mine over soon. but slowly over those damn speedbumps round yours :evil:
