Fitting new indicator arm on MK4
Hello all i need to fit a new indicator arm on my Mk4 P reg Polo..
I have the arm & needs fitting for the MOT as the old one doesnt cancel out..
I know i need to remove the steering wheel but it has an Airbag!
I'm after some tips on removal without the Airbag going off I've been told that i have to disconnect the battery???
Any tips would be great on doing this job...
Matt
  • Views 1k
disconnect the battery, and make sure you are wheels are pointing straight ahead, then theres two allen bolts behind the steering wheel, loosen them to get the airbag out (the bolts dont come all the way out), next there is a cable attached to the airbag, give it a pull, (it does come out, trust me). you should be able to see the big bolt that holds the steering wheel on, undo it, and you should be sorted, just make sure u put the steering wheel back on at the same angle, hence having you are wheels straight before u start
Cheers bro !! any idea if the battery has to be disconnected for a certain ammout of time ??
Also wll the airbag light be on after re-fitting ??
Do i havevto disconnect battery before removal for a certain ammount of time or can i just remove straight away ?? also will airbag light be on after re-fitting wheel??
I'm not sure, i did it pretty much straight away, and iv also got the problem that my airbag light stays on, but i think i myt have forgot to put sumthing back when reconnecting maybe, :S anyway, thats how you get it off
Thanks all
Matt
